How Do You Measure the Characteristics of a Chemical Reaction?
  • Thread starter Thread starter Equilibrium
    Confused
This discussion focuses on measuring the characteristics of chemical reactions, specifically using the example of the reaction between calcium carbonate (CaCO3) and hydrochloric acid (HCl). Key metrics for evaluation include the amount of carbon dioxide (CO2) produced, heat evolved, changes in pH, concentration of reactants, pressure changes, and conductivity. Participants highlight the complexity of calculations involved, particularly in determining heat and pressure changes, emphasizing the need for precise measurements and conditions for accurate results.
  • Understanding of chemical kinetics
  • Familiarity with stoichiometry
  • Knowledge of thermodynamics related to chemical reactions
  • Basic principles of acid-base chemistry
  • Research methods for calculating reaction enthalpy using calorimetry
  • Learn about measuring gas volumes and pressures in chemical reactions
  • Explore techniques for monitoring pH changes during reactions
  • Study the principles of conductivity measurements in solutions
Chemistry students, laboratory technicians, and researchers interested in chemical kinetics and reaction analysis.
Equilibrium
Geetings In relation to chemical kinetics i was confused about how I can determine the characteristics/(explanation?) of a chemical reaction?
for example:
[tex]CaCO_3 + HCl -> CaCl_2 + CO_2 + H_2O?[/tex]
1.)amount of CO_2 heat evolved
2.) change in pH
3.)amount of CO_2 / volume CO_2
4.) Change in concentration of reactants
5.) Change in pressure
6.) change in conductivity
I just don't actually get it...
[tex]Mg + O_2 -> 2MgO[/tex]
so the answer might be
1.) the amount of mass of Mg?
hmmm
What is the common technique in of determining these observations?
Eq, this is a common situation. I'll comment on each
1) I don't understand the question because heat is heat not CO2 heat. You can calculate the heat of a reaction but it is to long to explain here
2) change in pH is pretty easy since if mixed in the correct amount all of the HCl is consumed. If not the calculations get pretty intense and too hard to explain here.
3) this depends on the amounts of each
4) Same as above since you know how much CO2 is given off you could calculate the pressure rise but you need to know more about the size of the vessel.
5) I am sure there is a way to do it but I can't think of it!
13K
