Temperature sensitive, luminescent liquids?
The discussion centers on the feasibility of a new type of video display utilizing temperature-sensitive luminescent liquids, where an array of controllable heating elements would change the color of a thin liquid layer based on a video signal. Key challenges identified include the limited pixel switching times due to the thermal response of the liquid, the impact of convection currents causing image blurring, and the conduction of heat across the wall separating the heaters and the liquid, leading to distortion. The consensus is that while the concept is innovative, significant technical limitations hinder its practical application.
  • Understanding of thermoluminescent materials
  • Knowledge of thermal dynamics and heat transfer principles
  • Familiarity with video signal processing techniques
  • Experience with liquid crystal display (LCD) technology
  • Research thermoluminescent materials and their properties
  • Explore advanced algorithms for color response in temperature-sensitive applications
  • Investigate methods to mitigate convection currents in liquid displays
  • Study the thermal response characteristics of various liquids for display applications
Engineers, material scientists, and display technology developers interested in innovative display solutions and the challenges of using thermoluminescent liquids in video applications.
jasc15
I've had a vague idea for some a new type of video display for a while now. it consists of a thin liquid layer, sort of like liquid crystal i guess, with an array of controllable heating elements behind it. A video signal would be translated into a matrix of temperature levels for these elements, which would change the color of the liquid in front of it. The main advantage of this over the current digital video displays, is that the picture would be continuous, rather than discrete. Even though the signal would still be discrete, the colors of the "pixels" would blend into the adjacent "pixel". this would most certainly require very complex algorithms to determine the color; the color response might not be linearly dependent of temp, the response time of the color change might be too slow for a fluid picture, etc. So i guess my main question would be wether or not such a material exitsts, or if there is something similar already in use.
Will not work...even assuming (boldly) that you can create such a thermoluminescent liquid whose emission peak can be tuned across the entire visible spectrum.
1. pixel switching times are limited by thermal response of the liquid ...you'll be,. at best, watching everything in superslow motion
2. temperature gradients in the liquid will make convection currents that mix and blurr any image,
3. similarly, conduction across the surface of the wall separating the heaters and the liquid will cause blurring and distortion
Thanks for your input. i figured there would be some major limitations in the thermal response of the liquid, and i hadn't considered convection currents.
  • · Replies 32 ·
  • · Replies 21 ·
94K
  • · Replies 152 ·
12K
11K
