Proving the Work-Equation Relationship: A Mathematical Analysis
  • Thread starter Thread starter dan_c_101
    Work
The discussion revolves around proving the work-energy relationship mathematically, specifically focusing on the scenario where a mass accelerates uniformly under the influence of an applied force. The participants are exploring the connection between work done and changes in kinetic energy.
  • Participants are attempting to understand how kinetic energy is defined and how it relates to work done on an object. Questions arise about the factors that influence kinetic energy and the role of applied force in changing an object's velocity.
The discussion is active, with participants sharing insights and asking clarifying questions. Some have provided examples to illustrate concepts, while others are seeking further explanation on the relationship between kinetic energy and work. There is no explicit consensus yet, but various interpretations and approaches are being explored.
Participants are navigating through the mathematical definitions and implications of kinetic energy and work, with some expressing confusion over the equations involved. The original poster has reiterated the problem statement, indicating a focus on the mathematical proof required.
dan_c_101
Prove mathematically that if a mass (m) speeds up uniformly from v to v’ while being acted upon by an applied force (Fap) in the same direction as its displacement , then W = Ek = mv'^2/2 - mv^2/2.
I moved this to the homework forums. Dan, what do you know about kinetic energy KE and how it can be changed?
You get kinetic energy from mass x velocity^2 / 2. I am not sure how it can be changed besides the mass and velocity. Can you explain? Sorry the equation parts just confuse me, but can you help me somewhat to show how mv'^2/2 - mv^2/2 can equal the work done?
It is true that [tex]KE = \frac{m v^2}{2}[/tex]
But how did the object get its velocity? Who does the work on a baseball to get it moving with its velocity? What was the KE of the baseball before being thrown?
This sounds to me like your being introduced into momentum in terms of energy.you would need the Mass and Velocity of the applied force.
Example: Car Crashes into the back of another car (Fap being mass 1)
Car behind: Mass 1 (m1) Car in front: Mass 2 (m2)
Before Collision After Collision
Initial Velocity of Mass 1 (u1) Final Velocity of Mass 1 (V1)
Initial Velocity of Mass 2 (u2) Final Velocity os Mass 2 (V2)
So: 1/2(m1u1^2)+1/2(m2u^2)=1/2(m1V1^2)+1/2(m2V2^2)+Energy lost
Therefore: 1/2(m1u1^2+m2u2^2)-1/2(m1V1^2+m2V2^2)= Energy Lost
I suspect you are being asked to show that:
[tex]\int F \cdot ds = \Delta{KE}[/tex]
Hint: Make use of the fact that:
[tex]F = m \frac{dv}{dt}[/tex]
to change the variable of integration
