Thermodynamics - First Law (T-fitting)
The discussion focuses on applying the First Law of Thermodynamics to analyze airflow through a T-fitting in a compressed air line. The inlet conditions are specified as 1.6 MPa pressure, 40°C temperature, and 50 m/s velocity, while the outlet conditions are 1.4 MPa and 36°C. The main challenge is determining the outlet velocity and the rate of change of flow energy across the T-fitting, emphasizing the need to utilize the First Law effectively to solve for unknown variables, including the change in enthalpy (delta h).
  • Understanding of the First Law of Thermodynamics
  • Knowledge of fluid dynamics principles
  • Familiarity with properties of compressed air
  • Ability to perform energy balance calculations
  • Study the application of the First Law of Thermodynamics in fluid systems
  • Learn how to calculate flow energy changes in compressible fluids
  • Explore the concept of enthalpy and its role in thermodynamic processes
  • Investigate the effects of pressure and temperature on airflow in T-fittings
Mechanical engineers, thermodynamics students, and professionals working with fluid systems who need to analyze airflow and energy changes in compressed air applications.
kaeser1
Hey guys, I am having a problem trying to figure out what this question is asking for:
The air flow in a compressed air line is divided into two equal streams by a T-fitting in the line. The compressed air enters the 2.5cm diameter fitting at 1.6 MPa and 40 deg C with a velocity of 50 m/s. Each outlet has the same diameter as the inlet and the air at these outlets have a pressure of 1.4 MPa and temperature of 36 deg C. Determine the velocity of the air at the outlet and the rate of change of flow energy across the T-fitting.
I was able to figure out the velocities at the outlets but did not understand the rate of change of flow energy. If somebody could help me out, it would be great.
The problem obviously says first law, I believe you did not use the first law to find the velocities yeah? So try applying the first law. What variables are unknown? What is delta h?
  • · Replies 20 ·
20K
