Is this correct?Solved: Magnitude of Net Gravitational Force on Mass in Square
  • Thread starter Thread starter huh
    Gravitation Law
The discussion revolves around calculating the net gravitational force on one mass located at a corner of a square formed by four identical masses. The problem involves gravitational interactions and vector addition in a two-dimensional space.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore the use of gravitational force equations and the principle of superposition. There are attempts to break down forces into components and apply trigonometric functions for vector addition. Some participants question the reasoning behind distance calculations and the application of the gravitational formula.
The discussion is ongoing, with participants providing feedback on each other's calculations and reasoning. There is an emphasis on clarifying the correct approach to vector addition and the proper application of the gravitational force formula. Multiple interpretations of the problem setup and calculations are being explored.
Participants are addressing potential misunderstandings regarding the distances used in calculations and the implications of vector addition in the context of gravitational forces. There is a focus on ensuring that the mathematical reasoning aligns with physical principles.
huh
law of gravitation- is this better?
Could someone check this please?
Four identical masses of mass 600 kg each are placed at the corners of a square whose side lengths are 14.0cm (.14m).
What is the magnitude of the net gravitational force on one of the masses, due to the other three?
It's asking for the absolute value of the force.
Ok so the equation to use is (GMm)/r^2
And superposition of forces should be used, correct?
This is what I am trying: for the mass in the upper left hand corner
G= 6.67 x 10^-11
(G*600*600)/(.14^2)= 1.23 x 10^-3 for the masses beside and below
(G*600*600)/(.07^2)= 4.90 x 10^-3 for the mass diagonal from the one used
(.07 because the attraction would decrease by half, right?)
So adding these together:
(2)(1.23 x 10^-3) + 4.90 x 10^-3= 7.35 x 10^-3
or
(1.23 x 10^-3)+(-1.23 x 10^-3)+ 4.90 x 10^-3 = 4.90 x 10^-3
You have to break them up into x and y-axis components, add those, then use Pythagoras to add them back up.
I'm not sure of your reasoning here.
I would calculate the new distance by pythagoras and use that.
You're right - the attaraction DOES half, but you've used that fact to half your distance, squared your distance and substitued it into the equation which has given you a GREATER force for that diagonal one... which can't be right!
Also remember when you add, you're adding vectors.
Okay let's try again:
use cos(0) and sin(0)
x-component: 1.23 x 10^-3 y-component: 0
use cos(90) and sin(90)
x-comp: 0 y-comp: 1.23 x 10^-3
(G*600*600)/[(.14^2)+(.14^2)]= 6.13 x 10^-4 for the mass diagonal from the one used
(I saw something like this denominator in an example I found)
use cosine and sine of 45 degrees
x and y-comp: 4.33 x 10^-4
F(x)=0 + 1.23 x 10^-3 + 4.33 x 10^-4 = 1.66 x 10^-3
F(y)=4.33 x 10^-4 + 1.23 x 10^-3
using pythagorean theorem:
2.35 x 10^-3
  • · Replies 23 ·
