How Does a 10cm Cord Affect the Movement of a Box Suspended by Springs?
The problem involves a system of springs and a box, where a 10cm cord connects two identical springs supporting a 100N box. The setup includes a 50cm long spring with a spring constant of 500 N/m, and the scenario changes when the cord is cut, prompting questions about the box's movement and the work done by the springs.
  • Participants discuss the forces acting on the box and springs, considering energy approaches and free body diagrams. Questions arise about the initial movement direction of the box, the role of gravitational potential energy, and how to interpret the system's energy changes when the cord is cut.
Several participants are exploring different interpretations of the problem, with some suggesting energy conservation principles while others focus on the forces involved. There is an ongoing examination of the assumptions regarding the initial conditions and the effects of cutting the cord, but no consensus has been reached.
Participants note potential confusion regarding the initial conditions and the relaxed lengths of the springs, which may affect the calculations and assumptions about the box's movement. There is also mention of the need for clarity on the energy states before and after the cord is cut.
OVB
The problem is hard to describe, but ill give it a shot:
there is a 50cm long spring ( k = 500 N/m) hanging from the ceiling and a 10cm cord connecting it to another identical spring, which supports a 100N box. In addition, there are two (limp) 85cm cords. One is hanging vertically from the celing and is connected to the lower spring. The other one is hanging from the top spring and is connected to the 100 N box. If the 10cm cord in the middle is cut, I need to find out if the box moves up or down, how far the box moves, and the total work the spring forces do during the move.
Supposedly, the answers to the first two are up and 5cm. However, I am clueless as to how to begin this problem. Even when I draw all the forces in, nothing seems to make sense. I know it's a difficult problem, but I don't even know how to tell that the box is moving up.
Maybe I am not seeing the geometry correctly, but I can't imagine the initial move being upward. I would try an energy approach. It sounds to me like both springs will be supporting the same weight the moment the secondary strings become taught and will stretch by the same amount.
yeah, I have in a free body diagram (finally) a tension force exerted on one spring [upwards], and a spring force exerted on the block [upwards] (for the spring attached to the block) and a spring force exerted upwards with a tension force exerted downards, but because of Newton's 3rd law the tension on the rope is also pulling upwards on the block.
However, I don't see how to approach this as an energy problem since no speeds are given and I don't know how far the force acts on the block (after all I have to find the displacement in the second part).
The system starts from rest. If the block falls when the string is cut, it loses gravitational potential energy (GPE) and gains kinetic energy (KE) and accelerates until the secondary strings are taught and the springs start to stretch. A that point, the kinetic energy diminishes and spring energy (SE) increases.
The springs may have more energy before the string is cut than they do at any later time. I still don't see an initial upward move, but the springs will be shorter after the string is cut so I'm not saying it can't happen for sure. What is certain is that the total energy when the mass comes to rest is potential energy, and the total energy is conserved.
I solved the problem with Hooke's Law, with series and parallels. The second question is actually necessary to answer the first.
The energy calculation says it moves down 39.5cm before stopping, assuming I interpreted the problem correctly. I assume the 50cm springs are already strecthed initially by W/k = 20cm, so the equilibrium length is 30cm.
so...since both springs are stretched by the block, the restoring forces on the springs when the rope is cut causes the block to move upward? (i.e., back to equilibrium?).
So then do the combined potential energies of the two springs equal the change in potential energy (5 J), thus giving the distance raised of 5cm?
I don't know if I am correct in my assumptions, which is why I am asking these types of questions in this post.
Here is how I see the problem from your description. I don't ever see this 5cm rise being a particularly interesting point, even if the box does get there. The initial configuration is the 100N box at rest at the bottom of a spring (k = 500N/m) of length 50 cm hanging from a string of length 10cm connected to an identical spring above that is connected to the ceiling. The box is initially 110cm below the ceiling. Each spring is elongated 20cm by the 100N force [100N/500N/m = 0.2m]. The relaxed length of each spring is therefore 30cm. Without the box, the bottom of the second spring would be 70 cm below the ceiling. The series combination of the two springs has an effective spring constant of 100N/.40m = 250N/m.
When the string is cut, the relaxed positiion of the bottom of the top spring is 30cm (as before) with 85cm of string hanging down to the box and the bottom of the second spring is at the level of the box with 85cm of string above the spring. The relaxed level of both supports is 85cm + 30cm = 115cm from the ceiling. The weight of the 100N box is shared equally by the two springs, each supporting 50N of weight and stretching 10cm at equilibrium. The effective spring constant of the two springs in parallel is 100N/0.1m = 1000N/m. If the box were hung at rest it would be 125cm from the ceiling. Of course it is not at rest when it reaches this level.
You can choose the zero of GPE anywhere you want. If you choose the ceiling, the GPE will always be negative, but it is a convenient choice, so I used it. The total energy of the system is the inital GPE plus the energy of each spring elongated by x = 20cm (or the effective spring elongated by 2x = 40cm; either way gives the same spring energy)
E = ½kx² + ½kx² + Mgh_o = (500N/m)(0.2m)² - 100N(1.10m) = 20J - 110J = -90J
When the connecting string is cut, the box will find new positions with this much energy, most of which involve some amount of kinetic energy. But at the lowest point
the energy will be all potential. The springs will both be stretched by an amount y from the relaxed length of 30cm. At this point the total energy will be
E = ½ky² + ½ky² + Mgh_f = (500N/m)(y²) - 100N(1.15m + y) = -90J
Rearranging terms gives the quadratic equation
0 = (500/m)(y²) - 100y - 25m
The solution is
y = {[1 + sqrt(6)]/10}m = 34.5 cm (the negative root solution is unphysical. Why?)
The box stops 34.5cm below the new relaxed postion of the springs, or 115cm + 34.5cm = 149.5cm below the ceiling. The energy of the springs at this point is 59.5J which is 39.5J more than they started with. Where did this additional energy come from? It came from the loss of GPE which is now -149.5J compared to the initial -110J.
Now the springs are strethed well below the system equilibrium point. The box reverses position and heads upward. How high do you think it goes and why?
I just realized I made a mistake...the 50cm is the relaxed length of the spring. I apologize for not reading my question over carefully enough.
OK That will change things. My approach is still valid, but the answer could be quite different.
I can see a 5cm distance in the problem, but it is not relative to the starting point of the box. It is relative to the new height where the springs are relaxed.
I need to rethink the approach to this problem. Apparently these magical massless springs have a way of releasing energy without doing any work I can find. The problem is solved by finding the new equilibrium postion of the springs and the position of the box relative to that equilibrium position. Using the 50cm relaxed spring length, the new equilibrium position is above the initial position of the box, so it will experience an immediate net upwrd force when the connecting spring is cut. Energy will be conserved from that point onward, but it is not the same as it was before cutting the string.
At this point I am not usre what would happen if you did this with real springs. I guess it would be more of a conservation of momentum problem at the string cutting ceremony. The two springs (with masses) suddenly acquire momentum in opposite directions and thus acquire kinetic energies (something massless springs cannot have). That kinetic energy and momentum of the springs results in complicated inelastic collisions with the ceiling and the box.
