Why is Channel 1 Connected Across CR and LR Circuits?
  • Thread starter Thread starter momomo_mo
    Circuits
The discussion clarifies the connection method for Channel 1 and Channel 2 on an oscilloscope when measuring voltage across a capacitor and resistor in an AC circuit. Channel 1 is connected across both the capacitor and resistor to ensure a common ground reference, preventing potential damage or inaccurate readings. This method allows for accurate measurement of the voltage drop across the capacitor while maintaining a single ground point, which is critical for proper oscilloscope operation.
  • Understanding of AC circuit theory
  • Familiarity with oscilloscope operation
  • Knowledge of capacitor and resistor behavior in circuits
  • Basic principles of grounding in electrical measurements
  • Study oscilloscope probe grounding techniques
  • Learn about series circuits involving capacitors and resistors
  • Explore the implications of measuring voltage in AC circuits
  • Investigate common mistakes in oscilloscope measurements
Electronics students, electrical engineers, and technicians working with oscilloscopes and AC circuits will benefit from this discussion.
momomo_mo
Assume there is a capacitor and resistance connecting in series in a.c. Now channel 1 of the CRO acroos both the capaciotr and resistor and channel 2 across the resistor.The trace on channel 1 was taken as the p.d. across the capacitor and that on channel 2 as the current through the capacitor.
But I want to know why channel 1 is connected across both the capacitor and resistor and not only the capacitor?
Thank You
Most oscilloscopes measure from ground to the probe tip. If you connected one probe across the resistor and the other across the capacitor, you'd ground two different points in your circuit which would give you bad results at best or melt something at worst. So you connect both grounds together at one point, at the bottom of the resistor in your case, and the probe tips to the tops of the R and C. The difference between the two channels gives pure voltage across C.
