| Thread Closed |
Power Supply |
Share Thread |
| Nov26-06, 06:31 PM | #1 |
Power Supply
Is it unreasonable to buy or build a power supply circuit that is rated at 500V and 4Amps?
Thanks. I know 500V is possible, but not at that high an amperage. Anything in and around $5k would be fine. |
| PhysOrg.com |
engineering news on PhysOrg.com >> Multiview 3-D photography made simple >> Giant 3-D printed bugs shed light on insect anatomy >> A microphone that listens with light |
| Nov26-06, 07:38 PM | #2 |
Yea, would be alot cheaper to build one.
The problem would be finding a suitable step up 2000 W transformer to do the job. But there is a way to get around that, A simple step down transformer from 120 volts to 30 volts when connected in reverse will step up 120 V to 480 V. (turns ratio is 4) Assuming the insulation holds up, you might get up to 1 amp from one transformer. You would need four or more of these set ups in parallel to generate the required amperage at 500 V. After you rectified them, you a simple transistor regulator. |
| Nov26-06, 08:00 PM | #3 |
I dont care about price, I just want it to work.
| Nov26-06, 08:16 PM | #4 |
Power Supply
yes, will a little tinkering and tweaking could be done well under $500 bucks.
| Nov26-06, 08:21 PM | #5 |
I dont want to tinker, or tweak. I just want something that works. If you know of any power supplies or circuits that would do what I want, please let me know. |
| Nov26-06, 08:47 PM | #6 |
Recognitions:
http://www.lambda-hp.com/product_html/emspower.htm |
| Nov26-06, 08:49 PM | #7 |
Yes, you are the man sir marcusl.
This is EXACTLY the reply I was looking for, thank you! |
| Nov26-06, 08:58 PM | #8 |
Have you tried Agilent? They make (or used to?) some big ones like what you want. Check their website or give them a call. And don't expect to drop anything short of $5K...unless you build it yourself.
EDIT : Wrote this post when I hadn't yet seen marcusl's suggestion. |
| Nov26-06, 09:05 PM | #9 |
Recognitions:
| Thread Closed |
Similar discussions for: Power Supply
| DC Power Supply | Engineering, Comp Sci, & Technology Homework | 18 | ||
| Hi Everyone...AC-DC Power Supply ? | Engineering, Comp Sci, & Technology Homework | 5 | ||
| Power Supply | Electrical Engineering | 4 | ||
| Power supply from USB | Computing & Technology | 3 | ||
