How Does Elastic Collision Affect Particle Momentum?
  • Thread starter Thread starter Learning Curve
    Momentum Particle
The discussion focuses on calculating the mass of an unknown particle involved in an elastic collision with a proton. The proton, with a mass of 1.67 x 10^-27 kg, initially moves at 6 Mm/s and rebounds at 3.6 Mm/s after the collision. The momentum conservation equation is applied: P1 + P2 = P1' + P2', leading to the equation 3.006 x 10^-20 kg(Mm/s) = 1.08216 x 10^-26 kg(Mm/s) + P2. The next step involves using the relationship of relative velocities in elastic collisions to determine the unknown particle's mass.
  • Understanding of momentum conservation principles
  • Familiarity with elastic collision equations
  • Basic knowledge of particle physics
  • Ability to manipulate algebraic equations
  • Study the concept of elastic collisions in detail
  • Learn how to apply the conservation of momentum in two-body collisions
  • Explore the relationship of relative velocities in elastic collisions
  • Practice problems involving momentum and mass calculations in particle physics
Students in physics, particularly those studying mechanics, as well as educators and anyone interested in understanding the principles of elastic collisions and momentum conservation.
Learning Curve
Here's a question from my workbook that I can't seem to figure out.
A proton (mass = 1.6 x 10^27 kg) moves with a speed of 6 Mm/s. Upon colliding elastically with a stationary particle of unknown mass, the proton rebounds on its own path with a speed of 3.6 Mm/s. Find the mass of the unknown particle.
Let's start with what I know. I know that momentum = mass times velocity.
or p = mv
I also know that since it's elastic, it isn't losing any energy.
So I used the equation P1 + P2 = P1 + P2
(1.67 x 10^-27 kg)(6 Mm/s) + 0 = (1.67 x 10^-27 kg)(-3.6 Mm/s) + P2
I said 3.6 Mm/s was negative since it was in the opposite direction.
So from there I got:
P2 = 1.923 x 10^-26
But, from there I'm not sure where to go. I'm trying to find the mass of this particle, but I need to know it's velocity. :frown: Any help or hints is appreciated.
The relative velocities of the bodies before and after an elastic collision have a predictable relationship. You could use that to find the mass.
Dorothy
  • · Replies 32 ·
  • · Replies 16 ·
