Finding Turning Points of Morse Potential V(x)
The discussion revolves around finding the turning points of the one-dimensional Morse potential, defined by the equation V(x) = D(e^{-2ax}-2e^{-ax}). Participants are exploring the concept of turning points in the context of classical mechanics.
  • Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss the definition of turning points and their relation to classically forbidden regions. There are inquiries about graphing the potential and whether to invert the function to find extrema. Some suggest solving the equation V(x) = E to identify turning points, while others express confusion about the relationship between energy and potential.
The discussion is active, with participants sharing insights and clarifying concepts. Some guidance has been offered regarding the approach to solving for turning points, including substituting variables to simplify the equation. However, there is no explicit consensus on a single method or approach.
Participants are primarily focused on classical mechanics, which may influence their approach to the problem. There is mention of energy conservation and the need to understand the relationship between kinetic and potential energy at turning points.
Logarythmic
How can I find the turning points for the one dimensional Morse potential
[tex]V(x) = D(e^{-2ax}-2e^{-ax})[/tex]
It would be a good start to state the DEFINITION of "turning point"!
That's probably my problem then, what is the definition of "turning point"?
Can you graph the Morse potential ?
Daniel.
Yes I have graphed the potential.
Should I invert the function and find the min and max for x(V) ?
Turning points are related to the "classically forbidden regions", they are boundaries for these regions. It's easier to see if the problem is unidimensional and you can graph the potential.
Daniel.
Yes, but how do I determine the turning points?
By solving an impossible equation. Joking, just solve
[tex]V(x)=E[/tex]
.The eqn is not impossible. It can be brought to an algebraic one, a quadratic one, even.
Daniel.
But isn't
[tex]E = \frac{1}{2}m \dot{x}^2 + V(x)[/tex]?
Nope and yes. I assumed you wish to find the classical turning points of the Morse potential and for that you need to solve the eqn i wrote. At these turning points the classical KE is zero.
Daniel.
Yes of course. But then I've only got V(x) = V(x) ??
Nope, V(x) is equal to E, the total, given, energy. The E is the a generic notation for the the variable used to index the spectrum of the quantum Hamiltonian.
Daniel.
Ok, but I'm studying classical mechanics so I think I have to use another approach...
Alright, then, find the solution from other source and compare to what i said and suggested.
Daniel
I'm not aware of another approach. You start off with a certain amount of energy, which is a constant in a conserved system. But the classical turning points are when [tex]\dot{x} = 0[\tex], and then a moment later the velocity changes signs (i.e. the particle goes from going to the right to going to the left), so then you do what Dexter suggests, and hopefully understand why you're doing it.[/tex]
I understand this now. I get the equation
[tex]D(e^{-2ax}-2e^{-ax})-E=0[/tex]
Any tricks on how to solve this?
Yes, i already did tell you b4. Just substitute [itex]e^{-ax} =t[/itex] and then c what you get.
Daniel.
  • · Replies 19 ·
