Ball moving up an incline and coming down.
  • Thread starter Thread starter bolas
    Ball Incline
The discussion revolves around a physics problem involving a ball moving up an incline at an angle, where the acceleration is given as a fraction of gravitational acceleration. Participants are exploring how to determine the distance the ball travels up the incline before reversing direction, as well as the minimum initial velocity required for this motion.
  • Participants are discussing the application of kinematic equations to relate initial velocity, final velocity, acceleration, and distance. One participant presents their work using the equation of motion and calculates the relationship between initial velocity and distance. Others question the assumptions regarding the angle of the incline based on the acceleration provided.
The discussion is active with participants sharing their thoughts and calculations. Some guidance has been offered regarding the use of kinematic equations, and there is an exploration of the relationship between acceleration and the angle of the incline. Multiple interpretations of the problem are being considered, particularly regarding the angle and its implications.
There is a focus on the specific values provided in the problem, such as the acceleration being a fraction of gravitational acceleration. Participants are also navigating assumptions about the angle of the incline based on the given acceleration.
bolas
"a ball is rolled up an incline (at an angle x with the horizontal). For the angle x and the ball involved, the acceleration of the ball is 0.25g and directed down the incline. If the ball is released with speed v, determine the distance it moved up the incline before reversing its direction as a term of all other variables. What is the minimum initial velocity?"
Anyone can give me a hint on how to approach this problem? :(
Well, try to present us some of your work, there must be some thoughts on how to solve the problem.
This is what I have so far..
Using equation of motion..
Vf^2 = Vi^2 + 2*a*x
a = 0.25g = 0.25*(-9.8 m/s^2) = -2.45 m/s^2
Vf = 0 m/s
Vi = ?
x = s = ?
0 = Vi^2 + 2(-2.45 m/s^2)x
0 = Vi^2 - 4.9 m/s^2 * x
-Vi^2 = -4.9 m/s^2 * x
Vi^2 = 4.9 m/s^2 *x
x = vi^2/4.9 m/s^2
Gave up? :(
bolas said:
Gave up? :(
No need to give up, since the answer seems correct. :smile:
For this problem based on the given information that th acceleration is 0.25g down the incline plane, can I assume then that the angle is...
0.25g = gsin(theta)
theta = 14.47 deg ?
0.25g = gsin(theta)
theta = 14.47 deg ?
You have nothing to assume, since the accelearion is 0.25g, which must equal g sin(theta), so theta ≈ 14.47 deg.
