2 dimensional elastic collision
The discussion revolves around a two-dimensional elastic collision problem involving two particles with different masses and initial velocities. The original poster is attempting to find the angle of motion of the second particle after the collision, given the initial conditions and the angle of the first particle's motion post-collision.
  • Participants discuss the equations derived from conservation of momentum and energy, with some questioning the setup and assumptions made in the equations. There is a focus on how to reduce the number of unknowns in the equations to solve for the angle of the second particle.
The discussion is ongoing, with various participants providing insights on the equations and suggesting ways to simplify the problem. There is no explicit consensus on the approach, and some participants express confusion or disagreement regarding the use of angles in the momentum equations.
Participants are navigating the complexities of the problem, including the need to account for multiple unknowns and the implications of using angles in the momentum conservation equations. The original poster has expressed difficulty in solving the equations despite having established them.
teleport
Hey, I'm having problems with this:
A particle m with initial speed V1 collides with a particle at rest with mass 3m. After collision, particle with mass m is seen moving 30 degrees from its initial direction. What is the angle of motion of the 2nd particle after collision?
I can get three equations from momentum and energy for three unknowns but I can't solve it. Help?
Show me your equations.
x-component:
V1 = v1cos30 + 3VcosC
y-component:
v1sin30 = 3VsinC
Energy:
V1^2 = v1^2 + 3V^2,
where C is the unknown angle, v1, V are the final velocities of the m and 3m masses.
That's not exactly how I'd go about it. oops nevermind lol.
Well you see your equation 1 gives you what V1 is. So you can plug that into equation 3. Now you are only left with 2 uknowns, V and C. Now equation 2 gives you a way of getting rid of V. So now you only have 1 equation and 1 unknown, C.
btw, conservation of momentun does not use angles.
I should say conservation of momentum does not have to use angles. So if it helps, go ahead and use the total conservation of momentum equation.
that's wrong. Ill explain tomorrow why. Anyways thax.
Your equation in the y direction needs a negative sign.
Also, you will use angles.
Please can someone actually help?
Your equations seem correct (C will then be a negative angle). What's your problem in solving them ?
You need to solve for the quantities v1, V and C and you have 3 equations.
Try to eliminate v1 and V using the first two equations to write everything as a function of C in the third one, and you'll have an equation for your angle C.
  • · Replies 16 ·
