Need help in determining the lim
  • Thread starter Thread starter Equilibrium
The discussion revolves around evaluating the limit of a rational function as x approaches 4, specifically the expression \(\lim_{x\rightarrow 4}\frac{x^2 - 3x + 4}{2x^2 - x - 1}\). Participants are exploring whether factoring is necessary for this limit evaluation.
  • Exploratory, Conceptual clarification
  • Some participants suggest evaluating the limit directly by substituting x = 4, while others mention the possibility of factoring the expression. There is a discussion about the conditions under which factoring might be necessary.
The discussion is active, with participants offering different perspectives on whether direct substitution is sufficient or if factoring is required. There is no explicit consensus on the best approach, but multiple interpretations are being explored.
Participants are considering the continuity of the function and the implications of substituting x = 4, particularly regarding potential undefined values in the denominator.
Equilibrium
Hi
[tex]\lim_{x\rightarrow 4}\frac{x^2 - 3x + 4}{2x^2 - x - 1}[/tex]
this is lim x ->4 which is the cube root of the whole fraction ^
Is there any way to answer this because i can't really factor it...
Why not just evaluate the limit at [itex]x = 4[/itex]?
You don't need to factor it. It can easily be factored, since it's a ratio of quadratic polynomials.
Daniel.
Assuming f(x) is continuous at f(a) ([tex]\lim_{x \rightarrow a^{+}} f(x) = f(a) =\lim_{x \rightarrow a^{-}} f(x)[/tex]) you can always just plug in a. The only time you would need to factor is if f(x) is not continuous at a or if plugging in a would result in an undefined function (0 in denominator). So yea, as courtigrad said, just substitute x=4. :-)
  • · Replies 25 ·
  • · Replies 105 ·
13K
