Why Is a Voltmeter Connected in Parallel?
  • Thread starter Thread starter moomoocow
    Ammeter Voltmeter
The discussion revolves around the placement of a voltmeter in electrical circuits, specifically why it is connected in parallel with resistors rather than in series. Participants are exploring the fundamental principles of voltage measurement and the implications of meter placement on circuit behavior.
  • Participants are questioning the reasoning behind connecting a voltmeter in parallel, with some attempting to articulate the concept of voltage as a potential difference that requires two distinct points. Others are exploring the effects of meter placement on circuit functionality, particularly the implications of resistance when connected in series versus parallel.
The discussion is ongoing, with various participants providing insights into the nature of voltage measurement and the characteristics of voltmeters. Some guidance has been offered regarding the effects of resistance and the need for potential difference, but no consensus has been reached.
Participants are operating under the assumption that a basic understanding of circuit components, such as ammeters and voltmeters, is already established. There is an implicit exploration of the effects of meter resistance on circuit behavior.
moomoocow
hello
i know why an ammeter is always in series with the resistor(s)
but i don't know why a voltmeter is in parallel with the resistor(s)
can somebody explain this?
thank you:D
moomoocow said:
hello
thank you:D
If you put a voltmeter in series in a circuit, what voltage would it be measuring? When used in the usual way, you want the meter to not affect the circuit, but it always does have some effect.
In order to understand this you have to think about what each meter is measuring. I'll assume you know and understand what the ammeter is measuring, so we won't go over that.
The voltmeter, of course, measures voltage. If you remember back to your first physics class, voltage was defined as a potential difference between two points in space. Notice the word "difference." This implies that you need two distinct points in space at two distinct potentials in order to measure a potential difference between them, or a voltage. Voltages are never absolute, they are always measured with respect to something. If you were to hook up a voltmeter in series with a circuit component, you would read zero. This is because you've essentially connected your voltmeter in parallel to one point in the circuit. There can be no potential difference if there is no difference in space.
I hope that helps.
The Voltmeter is a very high resistance device...if connected in series, it blocks the main current in the circuit completely (resistance in series is greater than resistance when connected in parallel). So when the voltmeter is connected in parallel, only 1/(device resistance) is introduced into the circuit...... which is almost next to zero.
I hope this helped
  • · Replies 17 ·
