Torque and rotational dynamics
The discussion revolves around a problem in rotational dynamics involving a wheel that stops due to friction and an additional torque. The original poster presents a scenario where the wheel initially turns at 1200 turns/min and stops in 4 minutes, and then stops in 1 minute with an added torque of 300 N*m. The questions posed involve determining the moment of inertia of the wheel and the torque of friction.
  • Participants discuss converting angular speed from turns/min to rad/sec and calculating angular acceleration. There is an exploration of how to incorporate the supplementary torque into the equations. Some participants suggest writing separate torque equations for the two scenarios to find the unknowns.
The discussion is progressing with participants providing guidance on setting up equations based on the two different stopping scenarios. There is an acknowledgment that the moment of inertia remains constant across both cases, and participants are working towards formulating the equations needed to solve for the unknowns.
Participants note the need to consider both the initial torque due to friction and the additional torque when analyzing the problem. The time constraints for stopping the wheel in both scenarios are also highlighted as critical factors in the calculations.
inner08
A wheel is turning initially at 1200 turns/min and stops in 4 min because of friction. If we add a supplementary torque of 300 N*m, the wheel stops in 1 min.
a) What is the moment of inertia of the wheel?
b) What is the torque of friction?
Torque = alpha * I
time = w/alpha
f = ucF
Torque = -fR
I figured i'd start by converting the 1200 turns/min into rad/sec
(1200 *2pi)/60 = 126 rad/sec (this gives me angular speed - w)
Then I figured i'd find the angular acceleration using the angular speed that I just found with the time it takes to stop (in this case its 4min or 240seconds).
alpha = 126/240
= 0.525
Now at first I thought I could just substitute these in the equation Torque = alpha * I but it doesn't work out.
I then realized that they are saying that there is a SUPPLEMENTARY torque and it then stops in 1min. I thought it would then be something like "initial torque + 300 = something...". Does that make any sense?
Any help to clear this up would be appreciated!
You could think of it this way: [tex]M=\alpha_{1} I[/tex], and [tex]M+300=\alpha_{2} I[/tex]. The additional torque creates a new net torque, which creates a new angular deceleration. Try to work something out from here on. (P.S. Note that the moment of inertia is, of course, the same.)
You are given two (related) situations with two different accelerations. Find both accelerations, then write two "Torque = alpha * I" equations. Solve both equations together and you'll get your answers.
(Oops... radou beat me to it!)​
You are nearly there. Yes, Torque = alpha * I is a good equation to use.
You have got two cases. In the first one you have the unknown friction torque (call it T) and the wheel stops in 4 min. You worked out the acceleration alpha correctly.
In the second case you have an additional torque so (as you said) the torque is "initial torque + 300 = something" ... well, the "something" is just "T+300". This time the wheel stops in 1 min, so the value of alpha is different.
Using Torque = alpha * I for the two cases will give you 2 equations in the 2 unknowns (T and I) which you can solve.
Thanks a bunch! I got it :)
  • · Replies 35 ·
  • · Replies 25 ·
