Digital Elevator: Designing a 2 Floor System
  • Thread starter Thread starter JasonJo
    Digital Elevator
The discussion revolves around designing a two-floor elevator system, focusing on control mechanisms and stopping conditions. Participants explore various methods for implementing the elevator's functionality, including the use of H-bridges, reed switches, and logic gates.
  • One participant suggests using an H-bridge to control the motor direction for the elevator's movement.
  • Another participant proposes using two reed switches placed on the track to detect the elevator's position, recommending a method to connect power leads in differing polarities based on the reed switch states.
  • A question is raised about how the elevator would stop at the designated floors.
  • A later reply introduces the idea of using simple logic gates to manage the stopping conditions, suggesting the use of switches and resistors to create a logic system for controlling the elevator's movement.
Participants present multiple competing views on how to implement the elevator's control system, with no consensus reached on the best approach or stopping mechanism.
Participants have not yet resolved the specifics of the stopping mechanism or the integration of the proposed systems, leaving some assumptions and conditions unaddressed.
JasonJo
hey guys I am stumped on this project: make a 2 floor elevator. i am going to use an H-bridge to control which way the motor spins (ie. clockwise will make the elevator go up, counter - down).
anyway, here are the initial conditions to be met:
elevator must stop at both floors
elevator will only go up when it is down
elevator will only go down when it is up
any ideas to implement this? the class i am taking has no gone over microcontrollers, the farthest I've gone is MUX/DeMUX's.
PLEASE HELP!
Please stop it with the please help bit.
I will help (i am nice coder after all)
put two reed switches on the track (one on each floor) and a magnet on the back of the car(the thingy which goes up and down), insetad of a h-bridge, just connect the power leads in differing polatities using the reed switches.
+ --_
sw1---_
sw2---------- lead 1
- --_
sw1---_
sw2--------moveswitch-- lead 2
This should work, just don't mix up the two reed switches! (put them so that they engage only after they move to the floor)
Any questions so far?
how would it stop?
Simple logic gates.
Write out the conditions using some sort of switch (like the reed or a simple contact switch) with a resistor to pull logic high/low. Then its simply "up switch AND elevator at floor 1 switch" stuff, and you could write out the truth tables to show your work.
Cliff
  • · Replies 33 ·
  • · Replies 23 ·
