| Thread Closed |
Interview question |
Share Thread | Thread Tools |
| Nov30-06, 12:26 PM | #1 |
Mentor
Interview question
I like to toss a problem at interviewees to see how they think. My new question is so simple if looked at correctly, but so very counterintuitive that I caught a freshly minted PhD with it today.
A space vehicle with two thrusters is depicted below. +=====v=========+ |.....|.........| |.....+-----O...| |.....|.........| +=====^=========+ The thrusters (the 'v' and '^' in the diagram) direct their exhaust normal to the long axis of the vehicle. The two thrusters have the same Isp and generate identical force magnitude. The vehicle is perfectly symmetric about the long axis. A single fuel tank (the 'O' in the diagram) feeds the two thrusters and is located some distance from the thrusters along the long axis of the vehicle. The vehicle starts in a quiescent state at rest wrt some inertial observer. The two thrusters are activated simultaneously. The thrust from each thruster quickly ramps up to a constant value; both thrusters ramp up in an identical manner. After firing for some time, both thrusters are shut down simultaneously. Both thrusters ramp down to null firing quickly and in the same manner. Describe the behavior of the vehicle. |
| Nov30-06, 01:10 PM | #2 |
I'm no scientist by any means, but my first thought (and second) is (neutral colour answer--highlight it to read)
I expect that it would travel forward (to the right in your diagram) due to reaction thrust against the fuel tank. |
| Nov30-06, 01:13 PM | #3 |
My intuitive answer at first sight:
A slight shift to the right ? |
| Nov30-06, 01:21 PM | #4 |
Interview question
Danger's answer was my first thought too. But:
<that force is counteracted by the force directed against the fuel lines where they turn 90 degrees. Thus the rocket will go nowhere. Actually there will be a SLIGHT movement to the right while the centre of mass shifts as the fuel drains. The movement will stop once the engines stop. The craft will have moved less than its own length and will be stationary thereafter.> Thus, Vanesch is correct. And if I hadn't bothered to be so verbose, I would have beaten him. Also, here's your rocket with no dots: +=====v=========+ |. . . . . |. . . . . . . . | |. . . . . +-----O . . . | |. . . . . |. . . . . . . . | +=====^=========+ Copy this code and remove the spaces from the [ color] tags. +=====v=========+ |[ color="#E9E9E9"]. . . . . [/COLOR]|[ color="#E9E9E9"]. . . . . . . . [/COLOR]| |[ color="#E9E9E9"]. . . . . [/COLOR]+-----O[ color="#E9E9E9"] . . . [/COLOR]| |[ color="#E9E9E9"]. . . . . [/COLOR]|[ color="#E9E9E9"]. . . . . . . . [/COLOR]| +=====^=========+ |
| Nov30-06, 01:42 PM | #5 |
That's a good point, Dave. I was thinking of radiused bends in the fuel lines (I always assume that, because I always design things that way
). It seemed to me that the thrust on the perpendicular pipes would be distributed in various directions and thus not counteract that upon the front of the tank. Is that correct? In any event, they are shown as right-angle junctions which negates that.
| Nov30-06, 01:59 PM | #6 |
Mentor
Well, I've only thought a bit quantitatively about the question, but I'm getting a completely different answer - at the end of the day, in the original inertial frame, the ship is drifting to the left.
I'll try and think more about this when I get home, but I doubt that my daughter will let me. |
| Nov30-06, 02:48 PM | #7 |
| Nov30-06, 03:43 PM | #8 |
Mentor
Most of you saw that it drifts to the right while the thrusters are firing. Only George saw that it reverses direction when the thrusters are deactivated.
Way to go, George. During a design review, one engineer complained that the vehicle design is invalid. His complaint: The thrusters would plume the space station when the design vehicle approached the station for berthing. The designer, who really liked his design because of its very fine control capabilities, thought for a second. He said, "Ahah. My new design avoids plume impingement problems and still has very fine motion control when I fire both jets simultaneously. In fact, it has the exact same equations of motion as the first design!" His new design: +===============+ |...............| >-----------O---< |...............| +===============+ How does this vehicle have the same equations of motion as the first? |
| Nov30-06, 05:55 PM | #9 |
Mentor
The easy way to solve this is to invoke conservation laws. The conservation laws dictate what the answer must be. The causal actions that result in that answer are a bit harder to puzzle out, but that is often the case. For example, I don't have to model contact forces, bending, and flexing to know the final state after one spacecraft docks of one spacecraft with another. I just need to know their initial states and their configuration after the transients die out.
Back to the problem at hand: The fuel flowing from the tank to the thrusters has linear momentum. The momentum resulting from that flow has to be balanced by some other translational motion to keep the total linear momentum zero as seen by the inertial observer who saw the vehicle start at rest. The vehicle has to move to the right while the thrusters are firing. The vehicle attains a constant velocity as soon as the fuel reaches a constant mass flow rate. Ignoring transients, the exhaust gases in the first configuration have longitudinal velocity equal to the vehicle's velocity. When thrust terminates, the only moving entities in the closed vehicle+fuel+exhaust system are the exhaust and the vehicle. The exhaust has net momentum to the right. The vehicle has to be moving to the left after thrusting terminates. If you want to know what causes this behavior, you have to look at the transients. Imagine that you just closed the valve to a faucet a bit too quickly. That bang you just heard is momentum transfered from the no-longer-flowing water to the pipes. |
| Nov30-06, 05:56 PM | #10 |
10 char |
| Nov30-06, 06:16 PM | #11 |
Mentor
| Nov30-06, 07:00 PM | #12 |
Note that, if our dune buggy is floating in free space, you can no longer tell we're moving, and in fact, might not be. Yet I can still fire tennis balls out the sides. By your logic, I would start moving backwards. Or is it forwards? |
| Nov30-06, 07:14 PM | #13 |
Mentor
I said nothing of the sort. I used this as an analogy. Regarding the tennis balls, I said "you and a buddy are driving in a dune buggy at a constant velocity". The point of this analogy is that the balls are moving along with the vehicle longitudinally while they move away from the vehicle transversely. This is the exact same situation in the first configuration of the vehicle. The stream of exhaust doesn't lose its longitudinal velocity just because it left the vehicle, does it? To think otherwise is to revert to Aristotelian physics.
BTW, the equations of motion for this system are [tex]m_v(t)\ddot r_v(t) + \ddot m_v(t) l = 0[/tex] where [tex]m_v[/tex] is the mass of the vehicle, including the fuel remaining on the vehicle, [tex]r_v[/tex] is the velocity of the vehicle structure (not the vehicle center of mass), and [tex]l[/tex] is the vector from the point midway between the two thrusters and the fuel tank. The transients are the only thing that changes the vehicle's velocity. |
| Nov30-06, 07:16 PM | #14 |
Question:
Given this arrangment (where I've eliminated the fuel line factor): +=====v=========+ |. . . . . |. . . . . . . . | |. . . . . O. . .. . . . . | |. . . . . |. . . . . . . . | +=====^=========+ and a slight rightward motion (wrt to what I don't know), which way would the rocket move? |
| Nov30-06, 07:22 PM | #15 |
Mentor
By eliminating the fuel line factor you just eliminated the sole motive force. The vehicle moves with a constant, slight rightward motion (wrt to the same unknown what). Look at the EOM in post #13.
BTW, your vehicle will look better if you use a fixed-point font. Wrap the whole thing in a [ FONT="Courier New"] ... [ /FONT] construct. Also, thanks for showing me how to hide the periods in my original drawing. |
| Nov30-06, 07:59 PM | #16 |
OK, I wasn't sure if the fuel line factored in to your leftward force setup. It does.
I'm still not getting where the leftward force comes from. It's a force that - occurs after the thrusters stop - cancels the slight rightward motion caused by the shift in CoG - adds an additional component that starts it in a leftward direction |
| Nov30-06, 08:06 PM | #17 |
If you could do that, then you could create motion merely by shaping your vehicle like a wedge using the logic that the air would just slide off the slanted end while pushing on the flat end. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Interview question
| yo-yo interview question | Introductory Physics Homework | 3 | ||
| Question - Graduate Technical Interview for Nuclear Engineers | Academic Guidance | 1 | ||
| Interview Question | Classical Physics | 2 | ||
| 1st Interview ever | Academic Guidance | 7 | ||
