How Does Tension Affect the Speed and Wavelength of Waves in a Guitar String?
The discussion centers on the relationship between tension and wave properties in a nylon guitar string with a linear density of 9.0 g/m and a tension of 180.0 N. The calculated speed of the traveling waves is confirmed to be 141 m/s using the formula v = sqrt(T/u). To determine the wavelength, participants suggest analyzing the standing wave pattern by counting nodes and antinodes, as the frequency is not provided directly.
  • Understanding of wave mechanics, specifically standing waves
  • Familiarity with the wave speed formula v = sqrt(T/u)
  • Knowledge of linear density and its impact on wave properties
  • Ability to identify nodes and antinodes in wave patterns
  • Study the relationship between tension and wave speed in strings
  • Learn how to calculate wavelength using standing wave patterns
  • Explore the concept of nodes and antinodes in oscillating systems
  • Investigate the effects of different materials on wave propagation in strings
Physics students, music educators, and anyone interested in the mechanics of wave behavior in musical instruments.
bearhug
A nylon guitar string has a linear density of 9.0 g/m and is under a tension of 180.0 N. The fixed supports are L = 80.0 cm apart. The string is oscillating in the standing wave pattern shown in the figure. Calculate the speed of the traveling waves whose superposition gives this standing wave. (m/s)
The speed I calculated to be v=sqrt(T/u) = 141 m/s and I know this is right
Calculate the wavelength of the traveling waves whose superposition gives this standing wave. (m)
There are several equations I have been looking at to try and figure out the wavelength. v=lambda(f) but I don't have f.
k=2pi/lambda but I don't have k. I thought that maybe 0.8m would be considered x and use a sinusoidal equation but I still am lacking the amplitude and w. I just need some guidance on this problem.
You can figure out the wavelength by studying the pattern. Hint: Count the nodes/antinodes.
  • · Replies 23 ·
  • · Replies 29 ·
