Find the magnitude of the difference between the weights (temperature question)
The discussion focuses on calculating the magnitude of the difference between the weights of a solid aluminum sphere before and after cooling in water, utilizing Archimedes' principle. The sphere, with a radius of 2.34 m and an initial temperature of 89.0 °C, is submerged in water at 22.3 °C. The calculations involve the weight equations W1 and W2, where W1 accounts for the sphere's weight in water before cooling and W2 after cooling. The correct expression for the change in volume, ΔV, must be based on the surface area of the sphere multiplied by the change in radius, Δr, which is influenced by the coefficient of linear expansion for aluminum.
  • Understanding of Archimedes' principle
  • Familiarity with the coefficient of linear expansion for materials
  • Knowledge of volume calculations for spheres
  • Basic principles of thermodynamics related to heat transfer
  • Review the concept of Archimedes' principle in fluid mechanics
  • Study the coefficient of linear expansion for aluminum and its implications
  • Learn how to derive volume changes in geometrical shapes
  • Explore thermodynamic principles related to heat transfer and cooling processes
Students in physics or engineering, particularly those studying thermodynamics and fluid mechanics, as well as anyone involved in material science or heat transfer analysis.
physics1007
A solid aluminum sphere has a radius of 2.34 m and a temperature of 89.0 °C. The sphere is then completely immersed in a pool of water whose temperature is 22.3 °C. The sphere cools, while the water temperature remains nearly at 22.3 °C, because the pool is very large. The sphere is weighed in the water immediately after being submerged (before it begins to cool) and then again after cooling to 22.3 °C. Use Archimedes' principle to find the magnitude of the difference between the weights.
Weight of sphere in water before cooling W1 = W - ρ * g * V1 ρ = density of water
where W = actual weight of sphere and V1 the volume before cooling
Also, W2 = W - ρ * g * V2 Then W2 - W1 = -(V2 - V1 ) * ρ * g
V1 = 4/3 * π * r^3 V2 = 4/3 * π * (r + Δr)^3
Expanding (r + Δr)^3 and dropping any terms with Δr^3 or Δr^2 since these are very small
V2 = 4/3 * π * (r^3 + 3 * r * Δr)
V2 - V1 = 4 * π * r^2 * Δr
Δr = k * r * ΔT where k = coefficient of linear expansion for Al and ΔT the temperature change
This gives V2 - V1 = 4 * π * r^3 * k * ΔT
W2 - W1 = -4 * π * r^3 * k * ρ * g * ΔT
i get -2420.678 and that's not right. any suggestions?
You seem to have the right idea. I did not verify your number, but the problem asks for the magnitude of the difference in weights, which should be a positive number.
Besides the sign, you appear to have a problem with your ΔV expression, but I think you fixed it. ΔV should be the area of the sphere times Δr. In one place you have just an rΔr instead of r²Δr. I think you used the correct expression in your calculation.
  • · Replies 16 ·
  • · Replies 20 ·
