Distance relationship between primary/secondary coils
The forum discussion centers on an experiment involving AC transformers, specifically examining the relationship between the distance of a secondary coil from a primary coil and the voltage induced in the secondary coil. The setup included a constant AC supply, a large primary coil, a smaller secondary coil, and a voltmeter. Results indicated a sinusoidal pattern in the voltage readings as the secondary coil was raised, prompting inquiries about the governing equations for the induced voltage and the magnetic field's 3-D shape and intensity.
  • Understanding of AC transformer principles
  • Familiarity with electromagnetic induction
  • Knowledge of voltage measurement techniques
  • Basic grasp of trigonometric functions in physics
  • Research the equation governing induced voltage in transformers, specifically Faraday's Law of Electromagnetic Induction
  • Explore the mathematical representation of magnetic fields generated by current-carrying loops
  • Study the characteristics of sinusoidal voltage outputs in AC circuits
  • Investigate the effects of distance on magnetic field strength and induction
Physics students, electrical engineers, and anyone interested in the principles of electromagnetic induction and transformer design.
tima89
We have done a simple experiment on AC transformers.
Given: AC Supply. Big primary coil. Smaller secondary coil. Even smaller metal rod. (They all fit into each other) Voltmeter
What we did:
Connected AC supply to the primary coil. Voltage kept constant at all times
Secondary coil was placed in the primary coil, and connected to a voltmeter.
procedure:
Secondary coil was raised X distance from the primary coil. (Measured top to top).
Voltage on the secondary coil measured with each step.
Now, our results (Voltage vs. Distance) showed parts of a sin (or cosine) graph, and we are having a hard time justifying it. (i know that flux is BAcos(theta)
I would be very pleased if someone could explain it.
Thanks in advance
What equation should govern the pickup voltage as a function of distance? What equation describes the 3-D shape and intensity of the magnetic field created by a wire loop?
9K
