How Can Physics Solve These Complex Problems?
  • Thread starter Thread starter real2
This discussion focuses on solving complex physics problems involving buoyancy, oscillation, and simple harmonic motion. The first problem calculates the volume and weight of an iron anchor with a density of 7870 kg/m³, revealing that it appears 200 N lighter in water. The second problem analyzes a mass-spring oscillator with a mass of 0.500 kg and an oscillation period of 0.500 s, requiring calculations for various parameters including frequency and spring constant. The third problem involves a 10 g particle in simple harmonic motion, emphasizing the derivation of force equations and total mechanical energy.
  • Understanding of buoyancy principles and Archimedes' principle
  • Knowledge of oscillatory motion and Hooke's Law
  • Familiarity with simple harmonic motion equations
  • Basic calculus for deriving equations of motion
  • Study Archimedes' principle and its applications in fluid mechanics
  • Learn about Hooke's Law and its implications in spring systems
  • Explore the equations of motion for simple harmonic oscillators
  • Investigate energy conservation in oscillatory systems
Physics students, educators, and anyone interested in understanding complex mechanics problems, particularly in buoyancy and oscillatory systems.
real2
1. An iron anchor of density 7870 kg/m3 appears 200 N lighter in water than in air. (a) What is the volume of the anchor? (b) How much does it weigh in air?
2. An oscillator consists of a block of mass 0.500 kg connected to a spring. When set into oscillation with amplitude 35.0 cm, the oscillator repeats its motion every 0.500 s. Find (a) the period, (b) the frequency, (c) the angular frequency, (d) the spring constant, (e) the maximum speed, and (f) the magnitude of the maximum force on the block from the spring.
3. A 10 g particle is undergoing simple harmonic motion with amplitude 2.0×10–3m and a maximum acceleration of magnitude 8.0×10–3 m/s2. The phase constant is –π/3rad. (a) Write an equation for the force on the particle as a function of time. (b) What is the period of the motion? (c) What is the maximum speed of the particle? (d) What is the total mechanical energy of this simple harmonic oscillator?
Show your attempts at solving it or no one can help you.
