What is the speed of a bullet fired into a block on a spring?
The problem involves a bullet colliding with a block attached to a spring, focusing on the dynamics of an inelastic collision and subsequent energy transfer as the spring compresses. The subject area includes concepts from mechanics, specifically momentum conservation and energy conservation in oscillatory systems.
  • Mixed
  • Participants discuss the conservation of momentum during the bullet-block collision and the conservation of mechanical energy after the collision as the spring compresses. There are attempts to relate the energies involved and questions about the initial speed of the bullet.
Participants are exploring different equations related to momentum and energy conservation. Some have provided calculations and expressed confusion about the initial speed of the bullet, while others have confirmed the correctness of the equations used. There is an ongoing dialogue about the relationships between the variables involved.
Participants are working under the constraints of a completely inelastic collision and the need to determine the initial speed of the bullet based on the final state of the system. There are indications of uncertainty regarding the application of energy conservation principles and the values used in calculations.
candyq27
A 1.01x10^-2 kg bullet is fired horizontally into a 2.49kg wooden block attached to one end of a massless, horizontal spring (k=831 N/m). The other end of the spring is fixed in place, and the spring is unstrained initially. The block rests on a horizontal, frictionless surface. The bullet strikes the block perpendicularly and quickly comes to a halt with in it. As a result of this completely inelastic collision, the spring is compressed along its axis and causes the block/bullet to oscillate with an amplitude of 0.20m. What is the speed of the bullet?
1/2mvf^2 + 1/2Iwf^2 +mghf+ 1/2kxf^2 = 1/2mvo^2 + 1/2Iwo^2 +mgho+ 1/2kxo^2
Aw = v
Aw^2 = a
I'm not sure what to do w/ this equation. Do I use energy laws to figure it out? If I do then I'm not sure how to change the equation to find vf. I originally tried w= sqrt(k/m+M) and got 18.2m/s but that's wrong
Think of this problem as having two parts:
(1) The collision of bullet with block. What's conserved?
(2) The compression of the spring. What's conserved?
Well for the collision of the bullet with the block u have vom1=(m1+m2)v, but i don't know the intial speed so I'm not sure
and for the compression of the spring...? all I know is Hooke's Law is F=-kx, and U=1/2kx^2
Good. Momentum is conserved during the collision.
Good. After the bullet collides with the block, and the spring is compressed, what's conserved?
when they collide its an inelastic collision so the kinetic energy isn't conserved, so I'm not sure
You are right: During the collision, mechanical energy is not conserved (but momentum is). But what about after the collision, when the block/bullet moves and compresses the spring?
potential energy?
well since its oscillating then the w is conserved and the energy is also conserved
After the collision, total mechanic energy is conserved. What are the two kinds of energy relevant here?
1/2kx^2 + ?
candyq27 said:
1/2kx^2 + ?
Yes, spring potential energy is one kind. What's the other? (Hint: It's not conserved in an inelastic collision.)
kinetic 1/2mv^2 ?
Of course!
so then do i set everything equal? I'm still a little lost
is it (m1+m2)v = 1/2kx^2 + 1/2mv^2 ? but then how do i know the original v?
Momentum and energy are two completely different things--you can't set them equal.
Instead, get two equations--one describing conservation of momentum during the collision, the other describing conservation of energy after the collision--and solve them together to determine the initial speed.
What are those two equations?
well the momentum is m1v=(m1+m2)v so it's m1v-(m1+m2)v=0
and the energy is 0=1/2kx^2 + 1/2mv^2
so setting them equal i get...
0.0101v-2.5001v= 166.2 + 1.25005v^2
but then I'm confused
Use different symbols for V (bullet) and Vf (block, after the collision).
The energy is certainly not zero! The block moves after the bullet hits it. Initially it has only KE; when the block fully compresses the spring, it has only spring potential energy.
Stop trying to set them equal. :smile:
Instead, write the equation for conservation of energy and use it to figure out the speed of the block after the bullet hits it. That's your first step.
well if i just use energy and i use 1/2kx^2 + 1/2mv^2 i get v=11.5m/s
and then using momentum i do m1v=(m1+m2)v2 so it's 0.0101v= (2.5001)(11.5m/s) so v=2854.2, ok that's def wrong
How did you arrive at this answer?
i plugged in numbers and solved for v, I'm confused because i don't know what the intial is
I know you must have plugged numbers into something! I want to know the exact equation you used, and what values you used for m, k, and x.
I did 1/2kx^2 = 1/2mv^2
so 1/2(831N/m)(0.2m)^2 = 1/2(2.5001kg)v^2 so v=11.5m/s
Correct equation; Correct values. Good! But redo your calculation for v.
my reply didn't post...but i recalculated and got v=3.65m/s so then when i plug that into my other equation i get 902.5 m/s, that still seems really large
Well, it is a speeding bullet! (That's not an unusual speed for a bullet.)
ok good, thanks so much!
