Melting Ice in water and the final Temperature
The discussion revolves around the thermal dynamics of ice melting in water, specifically addressing the final temperature of the mixture when ice is added to water at different initial temperatures. The subject area includes concepts of phase transitions, freezing point depression, and thermal energy transfer.
  • Participants explore the conditions under which ice melts in water and question whether the final temperature can drop below 0°C. They discuss the implications of solutes on freezing point and the phase transition temperature of ice and water.
The discussion is ongoing, with participants examining different perspectives on the temperature behavior of the water-ice mixture. Some have provided insights into the effects of solutes, while others emphasize the phase transition at 0°C. There is no explicit consensus, as various interpretations of the problem are being explored.
Participants note that the original problem does not specify whether the water is distilled or contains solutes, which may affect the outcome. There is also uncertainty regarding the measurement methods for temperature.
wakejosh
I have heard that when ice mixes completely with water then the Ice will be completely melted and the temperature of the water willl actually be below 0 C, is this true?
Yes, it is possible to have water at a temperature less than 0oC if it has some solute (e.g. salt) dissolved in it, this is known as freezing point depression. In general, the more solute(salt) you add to a solvent(water), the lower the freezing (and hence boiling) point becomes.
But also in the absence of a solute, Icewater should be at 0C while the ice is melting, I believe, since it is at the phase transition temperature. Is that right Hootenanny?
well, he didnt say anything about ice, one of my freinds says he doesn't think the TA is right, and I don't know how much I trust him either. His observation was in regards to this question:
a 32 oz cup with 8 ounces of ice (250g about .25 liter volume) at zero degrees C is added to 750 g of water at 25 C.
he says that when they have mixed the Ice will be melted and the water can actually be below 0 C, he said nothing about Salt, nor does the problem.
From what you have said it sounds like when they are mixed the Ice will not be compltely melted and the temperature will be about 0 C. you guys think this is more accurate? I do.
This is indeed true, thermal energy is transferred from the water (and other surroundings) to increase the internal energy of the ice. As an aside, I have seen examples where the temperature of pure water (distilled) has been reduced to around -5oC before any ice has formed, however, once ice is formed the temperature increases again back up to 0oC.
Is the water from a tap or distilled? What are you measuring the temperature with?
none of that was specified in the question.
  • · Replies 17 ·
