| Thread Closed |
Stable or Unstable EQ pt. |
Share Thread | Thread Tools |
| Dec4-06, 03:41 PM | #1 |
A cube of sides B sits ontop of a hemisphere of radius R. Determine the conditions such that the cube is in a stable equilibrium. 2. Relevant equations A stable equilibrium is one in that the second derivative of the potential energy function is positive. U = mgh. 3. The attempt at a solution I figure that I need to write out the potential energy of the center of mass of the cube as it is displaced from the eq. pt. Also, as the cube is perturbed, the arclength of the circle traversed on the hemisphere is equal to the length from the middle of the one cube's side (originaly contacting the hemisphere) to the point of contact. I am having trouble writing down the vertical position of the c.m. as a function of displacement. Is it just this geometry that I need to think about or is something else missing? thanks |
| Dec4-06, 03:57 PM | #2 |
Recognitions:
| Dec4-06, 06:58 PM | #3 |
thanks, i'll give it a shot.
| Dec4-06, 07:54 PM | #4 |
Okay, I am stuck staring at this thing. I am trying to solve by drawing right triangles with one vertex at the c.m., another at the middle of one side of the cube, and the last at either the point of contact or such that the one leg of the triangle is vertical. As the cube is perturbed, I can see that the arclength between the original point and the point of contact can be constructed as one leg of my triangles. This will bring in the radius of the hemisphere into the equation. I am not sure where to go from here? thanks
| Dec4-06, 10:59 PM | #5 |
Recognitions:
| Dec5-06, 12:29 PM | #6 |
Okay I solved it! R > b/2. I wrote the height of the center of the cube w.r.t. the center of the sphere as: h = R cos(theta) +R*theta*sin(theta) +b/2*cos(theta). I then employed the small angle approx. for sin and cos. Then I took the derivative of h w.r.t. theta and made that greater than zero. I tried at first to take the derivative of h then use the small angle approx and this did not work. Why? I promise to learn latex soon.
| Dec5-06, 01:34 PM | #7 |
Recognitions:
| Dec5-06, 02:29 PM | #8 |
Doh, I forgot the product rule of differentiation for the R*theta*sin(theta) term. I just took the deriv of sin(theta).
Will I ever be a physicist??
| Dec5-06, 11:35 PM | #9 |
Recognitions:
| Thread Closed |
| Thread Tools | |
Similar Threads for: Stable or Unstable EQ pt.
| free neutrons are unstable: would a muon in say uranium be "stable"? | High Energy, Nuclear, Particle Physics | 5 | ||
| Proton: stable or unstable? | General Physics | 17 | ||
| Proton: stable or unstable? | High Energy, Nuclear, Particle Physics | 77 | ||
