Finding the Spring Constant - Help Algebra Issues
The discussion centers on calculating the spring constants for hydrogen (H2) and deuterium (D2) using their vibrational frequencies. The user applied the formulas T=2π√(m/k) and F=1/T to derive the periods T for both molecules, resulting in T values of 7.58x10^-15 seconds for H2 and 1.07x10^-14 seconds for D2. The calculated spring constants were approximately 6.87x10^29 N/m for H2 and 6.896x10^29 N/m for D2, indicating that the spring constants are nearly identical, differing by only 0.03. The algebraic approach was confirmed as correct, assuming accurate mass values were used.
  • Understanding of molecular vibrations and their relation to spring constants
  • Familiarity with the equations of motion for oscillating systems
  • Basic knowledge of algebra for isolating variables in equations
  • Concept of isotopes and their impact on mass in calculations
  • Study the derivation of spring constants in molecular physics
  • Learn about the implications of isotopic mass differences on vibrational frequencies
  • Explore advanced applications of Hooke's Law in molecular dynamics
  • Investigate the role of vibrational spectroscopy in determining molecular properties
Students and professionals in physics, particularly those focusing on molecular dynamics, chemists studying vibrational spectroscopy, and educators teaching concepts of oscillation and molecular behavior.
courtney1121
Finding the Spring Constant -- Help! Algebra Issues!
Molecular bonds can be treated like springs. From the vibrational frequencies of the bonds, one can determine the appropriate spring constants. Hydrogen, H2, has a vibrational frequency of 1.3192 X 1014Hz. Deuterium, D2, is an isotope of hydrogen and is twice as massive as hydrogen. It has a vibrational frequency of 0.9345 X 1014Hz. Do these molecules have the same spring constant? Explain.
I used the equations
T=2pi * square root m/k
F = 1/T
From the second equation, I got T=1/F. Since I know F of both bonds, I can find T.
For H2, T = 7.58X10^-15 and for D2 T= 1.07X10^-14.
mass for H2 is just m and mass for D2 is 2m
I plugged all these expressions into T=2pi*square root m/k, and isolated k, and got H2 to equal 6.87X10^29 and D2 to be 6.896X10^29. So they are only about .03 off which I think is pretty close to having pretty much the same spring constant. What I had problems with, was I am not sure whether I did the correct algebra for isolating k. Also, does it seem like I am approaching this problem correctly? Thanks!
Your approach looks okay, and the solution should be too, under the assumption you did the algebra correctly and plugged in the appropriate masses of the isotopes.
  • · Replies 17 ·
  • · Replies 17 ·
