Thread Closed
question on effort
Share Thread Thread Tools
Dec4-06, 06:12 PM   #1
question on effort
i have to design a vehicle that will accelerate up a 1/8 gradient hill to 11.11m/s in 15s
i need the effort required and wheel torque.
mass = 170kg
rolling resistance = 50N/t (0.05N/kg)
air resistance = 13.6N
g = 9.81m/s^2
i have calculated:
a = 11.11*(1/15) = 0.74m/s^2
theta = 7.18 deg
sin theta = 0.125 deg
so i have the effort as:
E = ma+mgsin_theta+Froll+Fair
E = 125.8+(170*9.81*0.125)+0.05+13.6
E = 347.9125N
is E the torque i need at the wheels?
if not how would you go about working it out.
i tried with a motor of 40N, wheel radius of 0.2m and gear ratio of 10:1
i worked it out like this.
axle torque = 40*10 = 400N
so to find the torque at the wheel do i divide the axle torque by wheel radius
400/0.2 = 2000 that seems wrong to me??
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Dec5-06, 08:38 AM   #2
Recognitions:
Homework Helper Homework Help
You need to multiply the rolling resistance with the mass:
[tex]E = m(a + R + g/8) + 13.6 = 357\ N[/tex]
which makes only a slight difference.
To find the torque at the wheel, [tex]\Gamma _w[/tex], you need to multiply the effort by your wheel radius. The effort will be shared by the four wheels (if all four a driving) reducing the torque to a quarter at each wheel.
In order to choose an appropiate motor you need to consider the torque of the motor,[tex]\Gamma _m[/tex], and gear ratio [tex]G[/tex] such that
[tex]\Gamma _m \times G = \Gamma _w[/tex],
http://www.blueink.com/CLASS/physcom1/gear.htm
Torque, [tex]\Gamma[/tex], is the turning effect of a force [tex]F[/tex]. If the force is applied with a longer lever arm [tex]r[/tex] the turning effect will be greater:
[tex]\Gamma = F \times r[/tex]
the S.I. units of torque is newtons meter.
Thread Closed
Thread Tools
Similar Threads for: question on effort
Thread Forum Replies
energy, effort, and mv Classical Physics 27
Door closing effort v/s Hinge Axis. Engineering Systems & Design 0
An effort to solve Zeno's motion Paradoxes General Discussion 91
An effort to solve Zeno's motion Paradoxes General Physics 1
An effort to solve Zeno's motion Paradoxes General Discussion 0
