Register to reply
Looking for a part, does it exist?
by Averagesupernova
Tags: exist
Share this thread:
Averagesupernova
#1
Dec5-06, 08:05 PM
P: 2,530
I have a project in which I need to find a part that would work as follows:
Imagine a smooth steel rod that is for instance .5 inches in diameter. Now imagine a block with a hole in it that fits around this rod. This block needs to slide easily and smoothly on the rod. However, sometimes I want to secure this block to the rod so it does not slide. It needs to be electrically controlled. At this point I'm thinking magnetic so it is just attracted to the rod. However, if it causes something inside the block to move and clamp to the rod that is fine too. This way the rod could be stainless steel or something non-magnetic. The duty cycle does not need to be 100%. Someone PLEASE tell me some type of device exists and point me where to find such a thing.
Phys.Org News Partner Science news on Phys.org
Study links polar vortex chills to melting sea ice
Lab unveil new nano-sized synthetic scaffolding technique
Cool calculations for cold atoms: New theory of universal three-body encounters
FredGarvin
#2
Dec5-06, 08:12 PM
Sci Advisor
FredGarvin's Avatar
P: 5,095
I can't say I have ever seen or heard of anything like what you are looking for. The closest I can think of off the top of my head is a standard linear bearing/drill rod assembly with a hand actuated clamp.
Have you checked with any motion control specialists?
Averagesupernova
#3
Dec5-06, 08:18 PM
P: 2,530
Of course, I would imagine something that doesn't exist. I have checked nowhere else at this point. It's something that popped into my head in the last hour or so as a solution. It NEEDS to be electrical. It will make enough on/off cycles for manual to be impractical.
FredGarvin
#4
Dec5-06, 08:22 PM
Sci Advisor
FredGarvin's Avatar
P: 5,095
Just because I don't know of anything doesn't mean they don't exist. I'll keep an eye out and ask some folks in the morning too.
Averagesupernova
#5
Dec5-06, 08:26 PM
P: 2,530
I find it hard to believe such a thing does not exist also Fred. I really appreciate your effort. I'll keep following leads here on the 'net. There are alot of motion control companies out there but I'm just not sure what you would call a part like this. Some kind of brake maybe?
Cyrus
#6
Dec5-06, 08:31 PM
Cyrus's Avatar
P: 4,777
Just curious, how heavy is this block?
Averagesupernova
#7
Dec5-06, 08:32 PM
P: 2,530
It doesn't need to be very heavy at all. It is used as an indicator and to actuate a switch.
Cyrus
#8
Dec5-06, 08:33 PM
Cyrus's Avatar
P: 4,777
How big a switch, like the one to flip on a light?
Also, what/how is it indicating?
Averagesupernova
#9
Dec5-06, 08:35 PM
P: 2,530
It might not even be a microswitch. I will most likely make it optical.
Cyrus
#10
Dec5-06, 08:39 PM
Cyrus's Avatar
P: 4,777
Why cant it be fixed to the rod at some location, and the rod move up and down? It would be easier to clamp the rod at the base to hold the block.
Averagesupernova
#11
Dec5-06, 08:44 PM
P: 2,530
The rod already moves. Up to 30 inches. The block can only be allowed to move within a 4 inch range. So it needs to slide sometimes. I really don't care to explain any more.
Cyrus
#12
Dec5-06, 09:07 PM
Cyrus's Avatar
P: 4,777
Top secret eh?
Well, without more information, it's going to be hard to know whats going on.
Averagesupernova
#13
Dec5-06, 09:17 PM
P: 2,530
Well, you don't need to know any more about what is 'going on'. I'm tied to what I've already explained. There is no way to 'move this other part instead'. The rod moves. Sometimes the block needs to move with it, sometimes it doesn't. It never moves very far before releasing.
Cyrus
#14
Dec5-06, 09:33 PM
Cyrus's Avatar
P: 4,777
I don't know. Possibly an electromagnet?
Averagesupernova
#15
Dec5-06, 09:36 PM
P: 2,530
An electromagnet. That's the assumption cyrus. However, has someone packaged up a handy little device that does what I described?
Cyrus
#16
Dec5-06, 09:40 PM
Cyrus's Avatar
P: 4,777
Nope, but I'll look online for ya.
RainmanAero
#17
Dec5-06, 09:40 PM
P: 83
Hi Averagesupernova,
Quote Quote by Averagesupernova View Post
Just a suggestion: I (and I have found several other engineers) often have difficulty envisioning something described in words alone. Engineers live by drawings, and its why we always start a problem with (how many times have we heard this?) "Draw a Free Body Diagram".
From what I can gather from your write-ups it sounds a bit like an electro-magnetic solenoid might do the trick. This is a device with a solid core (through which current is passed) and the outer "block" could and would be the electromagnet. I know some solenoids with 1-2 inch throws, but I am not sure of 4 inches or more.
If you could do a simple drawing it might help us help you. A solenoid is a discrete (ON/OFF) device such that when you energize it the core is pulled to one extreme of travel and when de-energized a spring holds it at the other extreme. But if you want to be able to continuously vary the position of the rod through the block, then you might want to look at something like a jackscrew or an E/M piston. More power required to operate these devices, however.
Another question that could be important: What sort of external loads might be applied to either the rod or the block?
Rainman
Danger
#18
Dec5-06, 09:44 PM
PF Gold
Danger's Avatar
P: 8,964
If I were to build something to that requirement, I'd score the top of the rod with a ****load of 'v'-shaped serrations and incorporate a wedge-shaped solenoid plunger into the block.
Register to reply
Related Discussions
Could null set exist as part of a physical model? Set Theory, Logic, Probability, Statistics 2
Do particles exist forever? Can Anything Exist forever? High Energy, Nuclear, Particle Physics 14
Energy transfer from cool part to hot part(q38) Introductory Physics Homework 1
Have part 1 of problem... stuck on part 2. help! Introductory Physics Homework 2
Do mathematical proofs exist, of things that we are not sure exist? Math & Science Software 43
