What Is the Eccentricity of an Orbit Given Vmin and Vmax?
  • Thread starter Thread starter HHveluj
    Orbit Satellite
The eccentricity of an orbit can be determined using the velocities Vmin and Vmax of a satellite orbiting Earth. By applying the conservation of angular momentum, the relationship between the maximum and minimum speeds can be established as rmin * Vmax = rmax * Vmin. This leads to a straightforward equation that expresses eccentricity (e) in terms of the velocities V and V0, where rmin = a(1-e) and rmax = a(1+e). The derived formula allows for the calculation of eccentricity directly from the given velocity parameters.
  • Understanding of orbital mechanics and satellite motion
  • Familiarity with angular momentum conservation principles
  • Knowledge of the equations for eccentricity in orbital dynamics
  • Basic grasp of gravitational forces and reduced mass calculations
  • Study the derivation of eccentricity formulas in orbital mechanics
  • Learn about the conservation of angular momentum in celestial mechanics
  • Explore the implications of varying velocities on satellite orbits
  • Investigate the relationship between energy, distance, and orbital parameters
Astronomy students, aerospace engineers, physicists, and anyone involved in satellite dynamics and orbital calculations will benefit from this discussion.
HHveluj
A satellite in an orbit around Earth has velocities between Vmin=V-V0 and Vmax=V+V0. Find the eccentricity of the orbit.
rmin=l^2/(Gm1m2*mu*(1+e))
E=(Gm1m2)^2*mu*(e^2-1)/2l^2
where mu = reduced mass = m1m2/m1+m2
I know all this formulas for eccentricity, but they all involve disctances/or energy, but not velocities! I don't even know how to start solving this... Any help/hints?
Thank you very much in advance!
You may use conservation of angular momentum to relate the speed at aphelion to the speed at perihelion. Recall, [itex]{\vec L} = {\vec r} \times {\vec p}[/itex]. Since at aphelion and at perihelion the motion is perpendicular to the position vector, you get that [itex]r_{min} v_{max} = r_{max} v_{min}[/itex]. Since [itex]r_{min} = a(1-e)[/itex] (*if* I recall correctly) and [itex]r_{max} = a(1+e)[/itex] , you get a simple equation relating the max and minimum speeds. You will get a simple expression for the eccentricity in terms of V and V_0.
Hope this helps.
Patrick
12K
