How to Apply Friction and Gravity to a 3D Velocity Vector?
The discussion revolves around applying the concepts of friction and gravity to a 3D velocity vector in the context of simulating an asteroid's trajectory near a gas giant. The original poster expresses difficulty due to limited physics and calculus knowledge, seeking guidance on how to implement these physical principles in a programming project.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the gravitational force acting on the asteroid, questioning how to apply the inverse square law and the implications of the asteroid's negligible mass. Discussions include the application of the coefficient of friction and how it interacts with gravitational forces in a 3D model.
Participants are actively engaging with the problem, offering insights into gravitational calculations and frictional forces. Some suggest keeping gravitational acceleration constant, while others explore the implications of the asteroid's trajectory and the effects of friction. Multiple interpretations of the physics involved are being discussed, indicating a productive exchange of ideas.
There is a noted lack of clarity regarding the parameters of the gas giant's atmosphere and how they relate to gravitational calculations. Participants are also considering the absence of contact forces in space when discussing friction.
fmucker
I need to know how to apply the coefficient of friction and gravity to a 3-coordinate (3D) velocity vector.
For my Intro to C Programming class, our final project is to write a program that simulates the trajectory of an asteroid passing a gas giant. The problem is, I haven't taken college Physics and this goes way, way beyond high school physics. I also have a limited understanding of Calculus (just barely passing Calc 1 right now). Here is the assignment:
Create a program that simulates the trajectory of an asteroid passing by a gas giant.
Below are parameters needed for the simulation. The units for time and distance have been chosen to simplify some of the parameters. Assume the asteroid mass is negligible.
Gravity = 1.0 (gravitational acceleration when at distance 1.0)
Atmospheric radius = 1.0 (distance from planet centroid to end of atmosphere)
Coefficient of friction = 100.0 (acceleration per time per speed while within atmosphere)
Distance (initial) from planet centroid in range [1.0, 10.0] input by user
Speed (initial) of asteroid in range [0.0, 10.0] input by user
Angle of approach in radians in range [0.0, 1.0] input by user (0 means aimed at planet)
Simulate the trajectory of the asteroid, starting at time 0.0, and with the position and velocity as specified by user input. Note that the user does not need to specify the asteroid initial position using 3 coordinates. The user is only asked for the relevant information. For your Cartesian coordinates, let the centroid of the gas giant be fixed at coordinate (0.0, 0.0, 0.0) and let the initial location of the asteroid be (Distance (initial), 0.0, 0.0). Set the third coordinate of the initial velocity vector to 0.0, and set its other coordinates to be non-negative.
Use the simplest model of friction. The asteroid is either within the atmosphere or outside it. If the asteroid is within the atmosphere, then it is subject to a constant coefficient of friction, regardless of its precise location.
(cut the rest off for space)
Thanks in advance for the help. I think I am being clear enough, but I have been studying for finals all day and my brain is almost fried. Please let me know if I need to specify things further.
I forgot to mention in my previous post that the physics side of this is not what is being graded, it is implimenting the physics into a program.
I get the impression that the Physics is not of a high standard in this project.
Lets try and clear the acceleration due to the gravitational attraction up first.
What other info regarding the gravitational attraction is given?
From your post above I get the impression that you should assume that the asteroid is experiencing a constant acceleration due to the attraction of the gas gaint all the way [0.0,10.0], that is even when the asteriod is inside of the gas gaint.
I have done a little research on the matter and I remember a bit from my high school Physics class. He is wanting us to use the inverse square law for gravity.
[tex]g=\frac{GM}{r^2}[/tex]
The problem is, the gas giant doesn't have a radius, simply an atmosphere that is 1.0 units around it's center. Maybe I am confused and it's atmosphere is supposed to be the radius of the planet?
Also, I have no idea how to apply a coefficient of friction. Would it be:
[tex]F_f = \mu N[/tex]
where-
[tex]\mu[/tex] is the coefficient of friction.
[tex]N[/tex] is the normal force to the contact surface.
[tex]F_{f}[/tex] is the maximum possible force exerted by friction.
How would I apply that to an object moving through space?
And the last thing I need to know, how do I apply this to a 3 coordinate model?
The r is not the necessarily the radius of the body. It is the displacement of asteroid from the centre of mass of the gas the giant.
I think in this case, since the force due to gravity is always directed towards the center of the gas giant, the path followed by it is part of a sphere. If we figure out how to do it in 2D, then the 3D version should be easy.
If you take, in the 2D model, the initial velocity of the asteroid to be inclined at an angle 'theta' to the x-axis, then the horizontal force acting on the asteroid is F(g) sin(theta) and the vertical force is -F(g) cos(theta) (i.e. in the -y direction).
However, if the mass of the asteroid is negligible, then how are you supposed to find the acceleration? Because, for a negligible mass, the acceleration should be infinity.
Are you sure about that?
For when the asteroid is outside the atmosphere, the equations for the trajectory in 2D are:
[tex]x(t)= -x+vcos(theta)+ (1/2)[F(g) sin(theta)/m]t^2[/tex]
[tex] y(t)= v sin(theta) - 0.5[F(g) cos(theta)/m]t^2[/tex]
where F(g) is force due to gravity and m is the mass of the asteroid and -x represents the initial position of the asteroid assuming it starts from the left of the gas giant and moves towards the right
Shouldnt it?
Shouldnt it?
Nope, the acceleration of an object in a gravitational field is independent of the object's mass.
Im sorry, I didnt know that. What should the acceleration be?
The acceleration of an object is given by Newton's second law, F = ma. Now, the force acting on an object in a gravitational field (ignoring friction etc.) is given by Newton's law of gravitation. Therefore, we can equate the two equations;
[tex]F = \frac{GMm}{r^2} = ma[/tex]
Notice that the m (mass of the object) cancel leaving;
[tex]a = \frac{GM}{r^2}[/tex]
Just as fmucker posted :wink:
:D I am sorry... I completely overlooked that...
No problem, don't let it discourage you from helping though since "While we teach, we learn" :wink:
Now, as frictional force opposes the tendency of motion, I think it should act in the opposite direction of the gravitational force... I don't know how you'll factor in the coeff. of friction though...
I think I am starting to understand how to factor in gravity. I use the function:
[tex]g=\frac{GM}{r^2}[/tex] and then use [tex]F_{g} =sin(\theta)[/tex] for x coordinate and [tex]-F_{g} =cos(\theta)[/tex] for y? If I am correct with this, I can program most of it and work in coef of friction when I get that figured out.
Err, maybe [tex]F_{a} =F_{g} sin(\theta)[/tex] and [tex]F_{a}=-F_{g} cos(\theta)[/tex] ?
No, as I gather, here [tex]a_x=\frac{GM}{r^2}sin(\theta)[/tex] and
[tex]a_y=-\frac{GM}{r^2}cos(\theta)[/tex]. If youre programming in C++, maybe I can help you...
The friction acts in a direction to oppose the motion, not the acceleration. It would be opposite gravity only if the object were headed directly toward the center of the gas giant.
Then friction would be a variable here, as the velocity of the asteroid will vary with time. How would you take into account the coeff. of friction here? Since there is no contact between surfaces, what would the normal reaction be? Or is there some other method to calculate friction here?
Well, I got the impression that you should keep the acceleration due to gravity constant in this project especially in view of the fact that the asteroid can go inside the gas gaint. If d is the distance of the asteroid above the atmosphere g would amount to
[tex]g = \frac{GM}{(R + d)^2}[/tex]
which comes to
[tex]\frac{GM}{R^2 + 2Rd + d^2}[/tex]
multiply with [tex]\frac{1}{R^2}[/tex] top and bottom to get
[tex]g(d) = \frac{1}{1 + \frac{d^2 + 2Rd}{R^2}}[/tex]
which follows from the statement that gravity is 1.0 at the surface. Since R = 1.0 this simplifies to
[tex]g(d) = \frac{1}{1 + d^2 + 2d}[/tex]
This models gravity outside the gaint as a function of the distance that the asteroid is above the atmosphere. Problem is what to do when it goes inside keep it at 1.0?
As others have pointed out, the physics in this problem is a bit cloudy (pun intended :smile: ) A very common assumption for objects moving through a gas is that the force of resistance is proportional to the velocity. The units specified in the origianl statement hint that this is the right assumption. If you write
F = -bv
then b is the coefficient of the force and has units [force/speed] or N/(m/sec). The "acceleration per time" given in the problem statement would have units of force/mass/time, and really makes no sense. But if you write
ma = -bv and solve for a then
a = -(b/m)v
The units of b/m would be the units of acceleration/speed, which is pretty close to the problem statement and is independent of the mass of the object. I would go with this expression using b/m = 100
The total acceleration is the vector sum of the attractive gravitational force and this resistive force.
How have you guys defined angle theta?
If you take the total distance of the asteroid from the center of the gas giant as 'r', then your expression becomes simpler. It also becomes easier to program. Also, if you assume the trajectory of the asteroid to be circular, 'r' remains constant.
Inside the atmosphere however, the easiest way would be to use an if-else construct to check in the begenning of the program if the asteroid is inside or outside of the atmosphere. In that case, you would have to factor in friction somehow, which I don't know how to do.
There is a third possibility however which must also be checked for: the asteroid could be outside the atmosphere intially and due to its velocity, enter the atmosphere, in which case the trajectory won't be circular... man this is messed up...
Theta would be the angle the velocity vector makes with the line joining the center of the gas giant and intial position of the asteroid
Theta is the initial angle entered by the user and then updated as gravity is applied to the asteroid. It is a trajectory program that could be circular, but normally will not. The asteriod needs the ability to orbit, crash, or just do a flyby. Because initial distance, speed, and angle can very, I need a general formula that will be constant with changing variables. As I said earlier, the programming will be no problem, it is the equations that are the problem.
As for the asteroid on the inside of the planet, wouldn't gravity simply increase exponentially (say it's .5 units in [tex](-.5^{-1})^2=4[/tex] right)? The force of gravity comes from the center of the planet in this problem.
It is well known that the force of gravity from a spherically symmetric distribution of mass depends only on the mass that is inside the surface of the concentric sphere that contains the object. (For example, the force of gravity between the Earth and an object at the center of the Earth would be zero.) In this problem it would be very reasonable to assume that the gravitational acceleration decreases as you approach the center of the gas giant. Since the problem states that there is an atmospheric radius, it would be reasonable to assume that the gas has uniform density within that radius. That density would be the total mass of the gas divided by the volume of the gas. Since you know the acceleration at the gas surface, you could find the (lower) gravitaional acceleration below the surface by seeing how the "interior" gas mass depends on r.
EDIT: The assumption of uniform density is also consistent with the assumption of a constant coefficient of friction for the retarding force.
The gravity will decrease inside because less mass is attracting the asteroid. What it boils down to is that you can ignore the shell of mass on the outside of the point where the asteroid is and just calculate the attraction due to the mass of the gaint "below" the asteroid.
My original question was: Is there any indication that you are suppose to let the acceleration due to gravity of the asteroid change as its distance from the gg (gas gaint) decreases? I got the impression that you need not change it for this project.
QUOTE]
With this definition, theta is the angle between the acceleration due to gravity and the velocity, and the resistive force acceleration is opposite velocity. In an approach phase (r getting smaller) the angle between the two accelerations is greater than 90º. In a receding phase, it is less than 90º. You will probably want the components of acceleration in the radial direction and perpendicular to the radial direction. Maybe you already have that.
The way to approach the problem is to divide the velocity vector into two components. One radial and one tangential. The radial component always points to the gg (at the origin of the coordinate system). The gravitational acceleration will increase only the radial velocity component according to
[tex]v_{n+1} = v_n + g \Delta t[/tex]
for a time interval of one and gravitational accelration of one this would come to
[tex]v_{n+1} = v_n + 1[/tex]
once you have the new velocity you calculate the new position coordinates of the asteroid
[tex]u_{n+1} = u_n + v[/tex]
for a time interval of one. Here a sign convention would help. The asteroid is approaching the gg so the radial velocity component will be negative.
  • · Replies 21 ·
11K
