Solve Pressure and Velocity of 4" to 2" Hose Problem
  • Thread starter Thread starter jlcowgill
    Fluid
The discussion focuses on calculating the pressure and velocity of water flowing through a 4" hose to a 2" nozzle. The resistance coefficient of the nozzle is 0.12, and the exit velocity at the nozzle is 24.4 m/s. Using the continuity equation, the upstream velocity (v1) is determined to be 6.125 m/s. Subsequently, Bernoulli's equation is applied to find the upstream pressure (P1) based on the calculated upstream velocity.
  • Understanding of fluid dynamics principles, particularly Bernoulli's equation
  • Knowledge of the continuity equation for fluid flow
  • Familiarity with resistance coefficients in fluid systems
  • Basic unit conversions between imperial and metric measurements
  • Study the application of Bernoulli's equation in various fluid flow scenarios
  • Learn about the continuity equation and its implications in fluid mechanics
  • Explore the effects of resistance coefficients on flow rates and pressures
  • Investigate practical applications of hose flow calculations in engineering
This discussion is beneficial for mechanical engineers, fluid dynamics students, and anyone involved in hydraulic system design or analysis.
jlcowgill
I have a 4" hose attached to a 2" nozzle, me resistance coeffient of the nozzle is .12, and the jet of water exiting the nozzle is 24.4 m/sec. The water is flowing from the 4" to the 2". What I am having trouble finding is Pressure 1 and the the velocity 1.
What I know is that P2=0, areas of the hose is 4" = 12.56 in^2 converts to .008m^2, 2" = 3.14 in^2 converts to .002m^2, I think Q=V2*A2 = 24.4*.002= .049 m^3/sec
then v1= 6.125 m/s?
then would I plug this into the bernoulli's equ.??
Thank You
Use the continuity equation to calculate the upstream velocity. If you know the velocity at the downstream loacation, this would equate to a certain mass flow rate. The mass flow rate will remain constant. So, since this is water and density can be considered constant, you have the old area, the density and the only unknown would be the velocity.
For the second part, once you have the upstream velocity, you can use Bernoulli to calculate the upstream pressure.
I was basically on the right track
thank you
Joe
  • · Replies 20 ·
12K
  • · Replies 30 ·
20K
