Circuit/Magnetic Field: Find EMF Induced
  • Thread starter Thread starter bsmack
    Field
The problem involves a bar sliding on rails within a magnetic field, aiming to find the induced electromotive force (emf) in the circuit formed. The context includes specific measurements such as the length of the bar, the strength of the magnetic field, and the initial velocity of the bar.
  • Participants discuss the relevant equations for calculating emf, with some suggesting the use of the universal flux rule. Questions arise regarding the correct interpretation of variables and units, as well as the appropriate length to use in the calculations.
Participants are actively engaging with the problem, with some providing guidance on the correct formula to use. There is an ongoing exploration of the values needed for the calculations, and a few participants are checking each other's reasoning and calculations.
There is mention of potential confusion regarding the multiplication factors and the specific lengths involved in the setup, which may affect the final calculation of the induced emf.
bsmack
A bar of length 22 cm that slides on two rails are connected together to make a complete electrical circuit. A magnetic field of strength 0.05 T directed out of the paper exists throughout the regions of space in which this machine is located. Assume that the distance between the rails l=20 cm and that initiaully the bar's sliding velocity is v=12 cm/s. Find the magnitude of the emf induced in this circuit.
What equations should I be looking at? If it's an equation involving an integral, please give the final equation and possibly an explanation.
The only equation I have available to me is emf = integ(E * dl). I don't know how I would get the electric field with the variables given, and I also don't know how I would get dl, as I don't think the length of the rails is given, just the length of the bar going across the rails and the distance between the rails.
use the universal flux rule.
emf = d(phi)/dt = B da/dt = Bl dx/dt = B v
So, my answer should be B*v=0.006 V? This is from a practice final, and the answer listed is 0.0012 V. Did we forget to multiply by 2 somewhere?
Check your units, bsmack. Does B v have the units of time derivative of flux? You see there is a slight typo in estel's final line. It should read [tex]B L v[/tex]. What is the value of L for your system? (Make sure you pick the right one!)
I think I figured it out. It should be emf = Bvl, correct?
Yes, you have it now. Just figure out what L is.
