Can you measure watts through heat?
  • Context: High School
  • Thread starter Thread starter dontdisturbmycircles
    Heat Measure Watts
The discussion revolves around the feasibility of measuring power consumption of a stove element through temperature differences. Participants explore the relationship between heat transfer, efficiency, and power measurement, considering theoretical and practical aspects of the approach.
  • Some participants suggest measuring the temperature of a stove element at different settings to infer power consumption, while others highlight the complexities of heat transfer rates involving conduction, convection, and radiation.
  • A proposal is made to use a well-insulated pot of water to measure how long it takes to boil a specific amount of water, establishing a ratio to estimate power consumption.
  • Concerns are raised about the efficiency of heating elements at different temperatures, with some asserting that heating elements are 100% efficient, while others question this assumption based on heat loss to the environment.
  • Participants discuss the implications of energy transfer, noting that while heating elements may be efficient in generating heat, not all heat is effectively transferred to the cooking vessel.
  • One participant mentions that measuring power with a multimeter could provide a direct comparison to temperature measurements, but warns about potential inaccuracies in heat transfer calculations.
There is no consensus on the efficiency of heating elements or the practicality of measuring power through temperature differences. Multiple competing views exist regarding the effectiveness of the proposed methods and the assumptions about heat transfer.
Participants express uncertainty about the impact of temperature on the efficiency of heating elements and the complexities of heat transfer mechanisms. The discussion highlights the dependence on specific conditions and assumptions regarding heat loss and measurement accuracy.
I am in grade 11 physics and haven't yet learned about thermodynamics or anything dealing with heat really.
I am wondering basically if you can reliably measure the power difference between two settings on a stove through temperature. i.e use a thermometer, measure the temp of the element at high, compare to temp at medium high. Could you tell the difference in power consumption? My guess is that you can, but I need to know for sure.
The difficulty is in knowing the heat transfer rate from the element. Since you have conduction, convection, and radiation, and all are temperature dependent (and not necessarily in the same way), it would not be easy to do.
So the trick would be to find a way to remove nearly all of the heat from the element to something easily measurable. Perhaps a large insulated pot of water, for example.
Would the efficiency/resistance/whatever of the element at different temperatures enter into the matter?
So theoretically this would be plausible (albeit impractical) by building a well insulated pot and sticking a thermometer in the top to measure how long it takes to boil a precise amount of water at a precise temperature. Then set up a ratio between the two results. Would this give you an reasonable ratio for power consumption?
I think that Danger's post would be my greatest worry, that the element's efficiency fluctuates with the temp setting.
No. All heating elements are 100% efficient.
Yes. And not just a ratio - you could calculate the actual amount of energy/power and compare it to what you measure with an ammeter/wattmeter.
great, thanks!
Actually I was thinking about this and it should have become apparent to me sooner that since 1 joule of energy raises 1ml of water 1^C, if I had 1250ml of water in an insulated pot, it would take 93750J of energy to heat it from 25^C to boiling. And of course I forgot but am now reminded that 1J/s=1watt. So I would just divide 93750J by however many seconds it took and I could get the watts.
I guess this scenario will reinforce the power formula in my mind, heh.
Please clarify, Russ. I thought that nothing was 100% efficient aside from superconductivity (from which work can't be extracted). Doesn't the resistance of a conductor change with the temperature?
Resistors are 100% efficient because all the energy in must come out in one form or another. (Radiation, convection, and conduction). The energy is not being partitioned to places like chemical reactions or sound which would result in less than 100% energy conversion.
You can do this very easily with one temperature measurement. You can measure the power going in using a multimeter, and compare that to the value you get using your thermometer measurement, and see how close they are.
Now, when you say reliably, keep in mind that in heat transfer, that means you are 40-50% off in your answer.
Thanks for that clarification, Cyrus. I had a different impression of what Russ meant. Although the element itself might be 100% efficient, that is not transferred to the vessel. A lot of the heat still goes into the air rather than into the vessel. If that were not the case, you could comfortably rest your hand on the heating element beside the vessel. (Which, I suppose, you can do with inductive cooktops.)
True - the element itself is 100% efficient at making heat, but you won't be able to capture all of it (though you can get pretty close).
...keeping in mind that all energy lost to inefficiency (in most instances I can think of) is in the form of heat. In a car, for example, you may get 35% of your energy sent to the wheels while losing 65% through the engine block and radiator. The total is 100%. In the example in this thread, it just so happens that all of what we are looking for is heat and it is the only form of energy transferred. No steam engine here.
You can even go a step further, though: at the end of the day, your car is right back where it started, so the total amount of mechanical work done is zero. All of the energy created by the engine eventually became lost to heat.
  • · Replies 23 ·
  • · Replies 33 ·
  • · Replies 24 ·
