BasketDaN
- 96
How much outward force is applied when liquid H2O freezes, turning into ice?
The discussion revolves around the outward force exerted by water when it freezes into ice, exploring the pressure conditions under which this occurs, the implications for materials like pipes, and the behavior of different substances under freezing conditions.
Participants express differing views on the behavior of materials under freezing conditions, particularly regarding the bursting of pipes and the factors influencing material failure. There is no consensus on the exact mechanics or outcomes related to the freezing of water and its effects on various materials.
Discussions include assumptions about pressure limits, material properties, and the conditions under which freezing occurs. The complexity of the interactions between temperature, pressure, and material strength is acknowledged but remains unresolved.
This discussion may be of interest to those studying material science, engineering, plumbing, and thermodynamics, as well as individuals curious about the physical properties of water and ice.
Originally posted by BasketDaN
Thanks. So, just to make sure I'm interpereting that graph correctly, if I were to freeze liquid H2O at about -10 degrees C, the volume would still increase (density would decrease to .92), as long as the pressure on it was not more than 10^8 Pa?
How thick would a pipe have to be to be able to resist 10^8 Pa (14,500 psi) ?
You didn't do the calculation...Originally posted by BasketDaN
But don't copper pipes usually burst when water freezes inside them? This freezing would usually be exerting around 14,500 psi, right? Which, by that post, would be less than what copper can handle anyway?
Like bending a paperclip until it breaks, repetitive stress (even if it seems small) can eventually cause metal components to fail.Originally posted by Michael D. Sewell
I think that copper tubing gets brittle with age. Russ probably can give you information on that.
Why is this? Does the bending induce dislocations in the lattice? This has never made sense to me (but, of course, it happens).Originally posted by russ_watters
