| Thread Closed |
Wind power generation help please |
Share Thread | Thread Tools |
| Dec13-06, 04:37 AM | #1 |
Ok, doing a project at the moment and this is one of the issues I have to overcome;
![]() When I put this data into a graph I end up with a curve rather than a straight uniformed line? ![]() Can anyone help me understand what I am doing wrong and guide me through what I am meant to be doing? I'm not doing physics or maths I am doing Arch & Construction Management. Many thanks! |
| Dec13-06, 05:34 AM | #2 |
Oh and I don't want the answer to the given question I want the formulas involved in understanding the relationship between swept area and power generation.
Just read the sticky and I think think I need to put it in the homework bit do i? |
| Dec13-06, 08:15 AM | #3 |
Recognitions:
You can use the statement ... "If you double the rotor diameter, you get an area which is four times larger (two squared)." This comes from the fact that the swept area is in the same ratio as the power produced due to the amount (volume per second) of air that flows through the turbine blades (if the airflow is kept constant) we have that
[tex]P \propto A[/tex] where A is the swept area and P is the power produced. Which in the case of the problem boils down to [tex]\frac{d_x ^2}{250} = \frac{d_{500} ^2}{500}[/tex] The volume of air that flows throught the turbine per second will be [tex]Av[/tex] where [tex]v[/tex] is the wind speed. A turbine converts (a fraction of) the kinetic energy of the air that flows through it to electrical energy. Which means that the power output will be (somewhat) directly proportional to this product. The reason why this will be only approximately true is that the turbine is more effective at some wind speeds due to the blade construction and orientation. |
| Dec13-06, 09:17 AM | #4 |
Thanks, this helped a lot with my calculations!
| Thread Closed |
| Thread Tools | |
Similar Threads for: Wind power generation help please
| Explain Why Wind Power Works But Permanent Magnet Power Doesn't | General Physics | 10 | ||
| home power generation | Electrical Engineering | 9 | ||
| wind power generation | Electrical Engineering | 1 | ||
| Power generation and storage | Engineering Systems & Design | 5 | ||
| Next generation power reactors | General Discussion | 12 | ||
