Motion on Incline Homework- Solve 215 N Box Force & Friction
  • Thread starter Thread starter young
    Incline Motion
The problem involves a 215 N box on an inclined plane at a 35.0º angle. Participants are tasked with analyzing forces acting on the box, including calculating components of weight, frictional forces, and the coefficient of friction under different conditions.
  • Participants discuss drawing free body diagrams and calculating weight components. Questions arise regarding the force of friction when the box is at rest and when it accelerates down the incline. There is also inquiry into the relationship between friction and the coefficient of friction.
Some participants have provided guidance on interpreting forces and applying Newton's second law. There is acknowledgment of correct component calculations, but uncertainty remains regarding the frictional forces and the coefficient of friction. Multiple interpretations of the problem are being explored.
Participants express concerns about their understanding and the complexity of the problem, indicating a need for clarification on the assumptions related to forces acting on the box.
young
A 215 N box is placed on an inclined plane that makes a 35.0º angle with the horizontal.
a) Draw a free body diagram which indicates all forces acting on the box.
b) Calculate components of weight force parallel and perpendicular to the plane.
c) If the crate is at rest, calculate the force of friction.
d) Now assume that the create accelerates down the incline at 5 m/s^2. What must force of friction be?
e) Find the coefficient of friction in part d
http://www.algebralab.org/img/d0c27dd9-1bf4-48da-96bd-89f6397bc762.gif
http://www.glenbrook.k12.il.us/gbssci/Phys/Class/vectors/u3l3e7.gif
I know how to draw the free body diagram. I think the components of the weight force is mgcos35 and mgsin35 which is 176 and 123 respectively. I don't know how to do questions c, d, or e.
4. Sorry
I know I sound stupid asking this amateur question. I really need to stop sleeping in physics class...
"respectively" will depend on which component you are stating first! The perp component is mgcos35.
For c, what can you say about the force of friction if the box is at rest? For d, use the equation F=ma, which you state on your web link, but remember that F is the resultant force! For e, do you know an equation involving the coefficient of friction?
Your components are correct. Beware of the signs of these vector-components, but first things first:
Following the picture you added in the link, we define the x-axis along the incline (positive direction go in UPWARD direction) and the y-axis is perpendicular to the incline.
The gravity on the box gives us indeed :
1) x direction : -mgsin35
2) y direction : -mgcos35
Watch your signs of the vectors. Both components are in the opposite direction of the positive directions of x and y axis, hence the -.
Next questions :
c) the box is at rest (read : not moving down). This means that friction is strong enough to avoid the box from coming down. In b) you calculated the gravitycomponent along the x axis, which is the force responsible for sliding the block down. Apply Newton's second law (in the x direction) with these data
d) again, apply Newton's second law with the given data (both in x and y direction)
good luck
marlon
yeah thanks guys i think i figured it out. Friction is the same as mgsin35 since its at rest. friction with the acceleration would be F=ma. coefficient is F=(mu)*N
  • · Replies 36 ·
  • · Replies 19 ·
