Is There a Square of a Rational Number Between Any Two Positive Rationals?
  • Context: High School
  • Thread starter Thread starter xalvyn
    Squares
The discussion revolves around the question of whether there exists a square of a rational number between any two different positive rational numbers. Participants explore this concept through various approaches, including rigorous proofs and intuitive reasoning.
  • One participant expresses uncertainty about the existence of a rational square between two positive rationals and suggests that the statement might be true.
  • Another participant proposes taking the square root of the rational numbers to explore the relationships between them.
  • A different participant discusses the need for a rigorous proof, referencing Dedekind sections and the properties of square roots of rational numbers.
  • One participant asserts that there is always a rational number between two unequal irrationals, implying that this might simplify the problem.
  • Another participant provides a reasoning framework that shows if two positive rationals exist, there is a rational number whose square lies between them, supporting the original claim.
  • A later reply indicates that the initial question is now understood, suggesting some level of clarity has been achieved.
Participants do not reach a consensus on the existence of a square of a rational number between any two positive rationals, and the discussion includes multiple viewpoints and approaches to the problem.
Some participants reference the need for rigorous proofs and the properties of square roots, indicating that assumptions about the continuity and properties of rational numbers are central to the discussion.
xalvyn
Hi all,
I think this sounds like a really simple and trivial question, but I've no clue as to where i should start:
true or false? between any two different positive rational numbers lies the square of a rational number. while i can't provide a construction of such a number, i somehow think that the statement is true.
thanks for any help
Assume there is no p, q such that p1/q1 < p^2/q^2 < p2/q2. What happens if you take the square root of all 3?
Hi,
the answer sounds obvious enough now :)
however, i was wondering if there is a rigorous way of proving this very elementary and trivial result.
for if we assume that if p1/q1 < p2/q2, then
sqrt(p1/q1) < sqrt(p2/q2), we'll have to prove this using 'dedekind section arguments', since the square root of a rational number is not necessarily another rational number.
i'll follow the definitions in my textbook closely:
i) if sqrt(p1/q1) < sqrt(p2/q2), then the lower section of sqrt(p1/q1) is contained in the lower section of qsrt(p2/q2); further
ii) there is at least one member of the upper section of sqrt(p1/q1) which is not contained in the upper section of sqrt(p2/q2), i.e. it is contained in the lower section of sqrt(p2/q2).
The first property is obvious enough; if x belongs to the lower section of sqrt(p1/q1), then x^2 < (p1/q1) < (p2/q2), and so x also belongs to the lower section of sqrt(p2/q2).
To prove the second property, we must show that there exists a rational number whose square lies between p1/q1 and p2/q2, which takes us back to the same question.
In some sense, the second property seems to follow naturally, because we 'feel' that the square roots of two different rational numbers must also be different; yet to prove this rigorously is rather frustrating.
There's always a rational between two nonequal irrationals, right? That should make this pretty easy.
Are you asking if p1/q1 < p2/q2, how to prove sqrt (p1/q1) < sqrt (p2/q2)? It works for any real positives a, b if a < b. a < b implies 1 < b/a, so sqrt (1) < sqrt (b/a) implies sqrt (a) < sqrt (b). Now, since between any two reals there exists a rational p/q, assume a and b are now positive rational numbers. It follows that there exists p/q such that sqrt (a) < p/q < sqrt (b) implying a < (p/q) ^2 < b, so between any two positive rationals there exists a square of a rational.
ok i think i understand now, thanks :)
  • · Replies 21 ·
  • · Replies 35 ·
  • · Replies 124 ·
29K
