Power of Water Pump (from continuity?)
The problem involves calculating the power of a water pump that is moving water from a flooded basement through a hose. The water is pumped at a specific speed and height, and the discussion revolves around applying principles from fluid dynamics, particularly Bernoulli's equation and energy considerations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss using Bernoulli's equation to determine pressure at the pump and subsequently calculate power. There are attempts to relate kinetic and potential energy to power output. Some participants express uncertainty about the application of Bernoulli's equation and the assumptions involved.
The discussion is ongoing, with various interpretations and calculations being explored. Some participants have provided guidance on using Bernoulli's equation and the relationship between pressure and flow rate to find power. There is a recognition of the complexity of the problem and the potential for multiple approaches.
Participants note the constraints of their coursework, including limited exposure to Bernoulli's equation and the expectation that the problem can be solved without extensive prior knowledge. There are mentions of potential losses in the system that may affect the final power calculation.
mbrmbrg
Water is pumped steadily out of a flooded basement at a speed of 5.5 m/s through a uniform hose of radius 1.2 cm. The hose passes out through a window 2.9 m above the waterline. What is the power of the pump?
[tex]R_v=Av[/tex]
[tex]R_m=\rho Av[/tex]
where P is power, W is work, and K is kinetic engery:
[tex]P=\frac{W}{\Delta t}[/tex]
[tex]W=\Delta K=\frac{1}{2}mv^2-\frac{1}{2}mv_0^2[/tex]
[tex]R_v=Av=\pi r^2v=(\pi)(.012 m)^2(5.5 m/s)=0.002488 m^3/s[/tex]
[tex]R_m=\rho Av=(1000 kg/m^3)(0.002488m^3/s)=2.488kg/s[/tex]
[tex]Power=\frac{W}{\Delta t}=\frac{\Delta K}{\Delta t}=(\frac{1}{2}m{v_f}^2-\frac{1}{2}m{v_i}^2)/(\Delta t)[/tex]
Take delta time to be 1s, initial velocity (water sitting in basement) to be 0m/s, final velocity (water in pipe) to be 5.5m/s, mass dealt with in one second is 2.488kg.
NOTE: I think my error lies here; something was assigned a totally evil value. Probably my choices of velocity.
But going with the values I picked, I got [tex]P=(\frac{1}{2})(2.488 kg/s)(5.5 m/s)^2=37.63W[/tex]
This be wrong. I be sad.
As a first thought, use Bernoulli to calculate the pressure at the pump knowing the velocities and elevation changes. Use the pressure to calculate power via
[tex]P = pQ[/tex] where
[tex]P[/tex]= Power
[tex]p[/tex]= pressure
[tex]Q[/tex] = volumetric flow rate
You seem to be overlooking the [itex]\rho gh[/itex] term.
AM
The [tex]\rho g h[/tex] is taken care of in Bernoulli in the [tex]\gamma \Delta z[/tex] terms.
I don't think I know that much Bernoulli... the only Bernoulli equation that we've covered in class so far is[tex]p+\frac{1}{2}\rho v^2+\rho gy=constant[/tex]. And the problem claims that it can be solved without even that. Sigh.
That's just a different form of it. That is correct. Like I mentioned, you can calculate the pressure at the pump, i.e. P1 from Bernoulli. You know the constant velocity and density, so the two terms with velocity will drop out.
Once you get the pressure at the pump from the Bernoulli equation, use the second equation I mentioned to calculate the power.
A quck run through gets about 71 W. Is that close to your answer?
The power is the kinetic + potential energy added to the water per unit time. You have figured out the kinetic energy/time at 37.6 W. What is the potential energy added per unit time?
AM
A simple equation for power, P, is:
P = Q * ((gamma)force density) * h
I get 70.7 W
Of course this doesn't account for any parasitic losses.
No matter what I do, I keep getting Power in the hundreds of Watts.
Here's the latest work (and thank you for putting up with me!)
Where the 1's are the pipe at the waterline, and the 2's are the top of the pipe:
[tex]p_1+\frac{1}{2}\rho {v_1}^2+\rho gy_i=p_2+\frac{1}{2}\rho {v_2}^2+\rho gy_2[/tex]
Since v is constant along the pipe, the 0.5*rho*v^2 terms cancel.
Let the waterline be 0m.
[tex]p_1=p_2+\rho gy_2=10^5 Pa + (1000kg/m^3)(9.81m/s^2)(2.9m) = 128449 Pa[/tex]
OK. Now to find the force that the pipe exerts.
[tex]p=\frac{F}{A}[/tex] so [tex]F=pA=(p)(\pi r^2)=(128449 Pa)(\pi)(.012 m)^2=58.11N[/tex]
Lastly (*gasp*) [tex]Power=Fv=(58.11 N)(5.5 m/s)=319.6 W[/tex]
And I lose yet again...
One kg of stationary water in the basement is lifted 2.9 m. and moved to a speed of 5.5 m/s. This is an increase of mgh + .5mv^2 = 1*9.8*2.9 + .5*1*5.5^2 = 28 + 15 = 43 Joules. Since the flow rate is 2.5 kg/sec., the power is 43*2.5 = 107.5 Joules/second.
AM
You're close. Bernoulli will reduce to [tex]p_1-p_2 = \rho g(y_2-y_1)[/tex]
The [tex]p_1-p_2[/tex] term is equal to the pressure that the pump is putting out since the pipe is exiting to atmospheric pressure.
Your next step is where you went wrong. That is not the way to calculate pump power. The power from the pump is a function of pressure and flow rate. Look at the equation that has been given to you twice:
[tex]P = p Q[/tex]
[tex]P = p Q[/tex]
Yessir. Thank you, sir. Sorry for disregarding you, sir.
Now that the final's over, I no longer have any compunctions about using equations not covered in class or the textbook :wink:
I agree with Andrew's calculation:
power = (GPE created per second) + (KE created per second)
= 108.39... Joules per second
(+ losses due to friction, etc)
  • · Replies 27 ·
