Force and potential energy of a particle
The discussion revolves around the calculation of potential energy change for a particle subjected to a conservative force defined as F(x) = bx + a. The specific scenario involves a particle moving along the x-axis between two positions, with participants exploring the relationship between work done and potential energy.
  • Participants discuss the relationship between force and potential energy, with some recalling that force is the negative derivative of potential energy and that potential energy can be derived from integrating the force. Questions arise regarding the role of potential energy in the context of work done and the specific calculations involved.
The discussion is active, with participants sharing their thoughts on the relationship between work and potential energy. Some guidance has been offered regarding the calculation of potential energy and its connection to work done, though there is still exploration of the implications of these concepts.
Participants are navigating the definitions and relationships between work, force, and potential energy, with some uncertainty about the implications of their calculations and the assumptions underlying the problem.
dkgojackets
A conservative force F(x) = bx + a acts on a 2.61 kg particle, where x is in meters, b = 6.3 N/m, and a = 4 N. Calculate the change in potential energy of the particle as it moves along the x-axis from x1 = .749 m to x2 = 4.81 m.
work-energy theorem, PE = mgh
My first thought was simply 0, since it was going along the x-axis and therefore no change in PEg and no springs or such, but that was wrong. I solved that the work done by the force = 87.3556 J. I also solved initial kinetic energy if the final speed was 16.8 m/s, which was 280.9676. KEi + W = KEf. Where does the potential fall in?
For a conservative force, what is the relation between the force and its potential?
I remember doing potential energy diagrams...and force is the negative derivative of one. So potential is the integral of force? That's what I did to determine the total work done, though.
Right, that's all you have to do. Find the potential and calculate the change.
So it is the same as the work done?
Yes, it is.
Ack, but negative. Got it now.
13K
