Projectile Initial Velocity at 38 Degrees: Find Help and Solutions!
  • Thread starter Thread starter ataglance05
    Projectile
The discussion revolves around a projectile motion problem where a projectile is launched at an angle of 38 degrees with an initial horizontal velocity of 3.3 m/s. Participants are attempting to determine the initial velocity of the projectile, considering the effects of gravity.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are exploring how to calculate the vertical component of the initial velocity using trigonometric functions and questioning the validity of their calculations. There is also a discussion on the correct application of the Pythagorean theorem in this context.
The conversation includes attempts to clarify the relationships between the components of velocity and the overall initial velocity. Some participants express confusion about the use of variables and the calculations involved, while others provide corrections and alternative approaches without reaching a consensus.
There are indications of confusion regarding the definitions of variables and the application of trigonometric identities. Participants are also grappling with the implications of the given angle and initial velocity in their calculations.
ataglance05
need help on projectile!
A projectile is fired at an angle of 38 degrees with respect to the x-axis and with an initial velocity in the x direction of 3.3 m/sec. (gravity=10m/sec^2)
a)whats the initial velocity of the projectile?
a) i think Vy=Vi(sin38 degrees)
and a^2+b^2=c^2
I first want to get the Vy by using: Vy=Vi(sin theta)
so, Vy=3.3m/sec(sin 38 degrees)
Vy=2.03 m/sec
now, (2.03)^2 + (3.3)^2= r^2
so r or the initial velocity of the projectile =3.87 m/s ?
Your reasoning is circular and incorrect. First you are using Vi to find Vy, and then you are using Vy and Vx to find what you called r, which is in fact Vi. You are not getting r = Vi because you did not know Vi when you used it to find Vy. What you are given in the problem is Vx and a launch angle. How do you find Vi from the given information?
let me try again, with the right variables and numbers:
Viy=Vi/(tan theta)
Viy=3.3 m/sec / (tan 52 degrees)
Viy=2.58 m/sec
so then i do the phythagorem (sp?) theorem:
Vix+Viy=Vi
(3.3^2)+(2.58^2)=Vi
4.19 m/sec=Vi !?
i believe that's correct
Viy=Vi/(tan theta)
Viy=2.58 m/sec
Vix+Viy=Vi
(3.3^2)+(2.58^2)=Vi
4.19 m/sec=Vi
Your answer is correct. However the lines in bold should read Vi2=Vix2+Viy2
Vi=sqrt{(3.3^2)+(2.58^2)}.
The Theorem to which you are referring is the Pythagorean Theorem (named after Pythagoras).
  • · Replies 30 ·
