| Thread Closed |
buffons needle variation |
Share Thread |
| Dec20-06, 05:52 PM | #1 |
In the "buffons needle" riddle you have a paper with horizontal lines in it all 1 unit apart and you drop a needle 1 unit long - you have to calculate the chance that the needle will hit a line. but i remembered the riddle wrong so instead i tried to solve the same question with both horizontal and vertical lines (graph paper). all of the cells are 1X1 unit. i got that the chance of hitting a line is:
3/pi which is about 95% is that right? Thanks. |
| Dec20-06, 07:55 PM | #2 |
Recognitions:
I get the same answer. Also, note the result proves pi>3, and since it's obviously pretty likely the needle will hit a line, it shows pi is pretty close to 3. Maybe you can get other approximations for pi using a similar method, which is ironic considering the point of the original problem was to empirically approximate pi.
| Dec21-06, 03:25 AM | #3 |
I wrote a program that simulates a needle falling 10000000 times and counts the times that it hits a line. using that i got that
3/pi = 0.95521 or pi = 3.14067 - ok but i guess that this method of calculating pi doesn't converge very fast. |
| Thread Closed |
Similar discussions for: buffons needle variation
| fluid in hypodermic needle | Introductory Physics Homework | 6 | ||
| Buffon's Needle problem (Geo Prob) | Set Theory, Logic, Probability, Statistics | 4 | ||
| Period of oscillation of dip needle | Advanced Physics Homework | 2 | ||
| compass needle | Introductory Physics Homework | 19 | ||
| The Painless Needle | Biology | 14 | ||
