Thread Closed
Integral of 1/ln(x)
Share Thread Thread Tools
Dec26-06, 03:38 PM   #1
Integral of 1/ln(x)
I have a formula to solve, which I am having trouble solving, it is a differential equation fo sorts
[tex]\int{\frac{1}{m\log(m/mo)}{dm}=\int{\frac{1}{t}}{dt}[/tex]
could someone help me solve the indefinite integral of such an equation!!
the m multiply of the right handside is suppose to be dm and likewise with the t on the left hand side sorry for any confusion!!!
Thanks for any help
N
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Dec26-06, 04:36 PM   #2
Quote by NEWO View Post
Thanks for any help
N
Make a substitution u=log(m/mo). I assumed that mo in the denominator was supposed to be mo.
Dec26-06, 11:04 PM   #3
How can this work? Its an indefinite integral and the answer's definate. One's with respect to m and the other t. I'm sure it doesn't change the u substitution, but shouldn't everything be noted as rigorously as possible?
Dec26-06, 11:24 PM   #4
Integral of 1/ln(x)
Quote by Dbjergaard View Post
I think everything is as already as rigorous as possible, at least for all that the original poster has given, however, I have no idea what you mean by "Its an indefinite integral and the answer's definate."
Dec27-06, 01:21 AM   #5
Recognitions:
Gold Membership Gold Member
I guess that was wrong.
Dec27-06, 01:28 AM   #6
Quote by robert Ihnot View Post
Something like [tex]\int{\frac{1}{m\log(m/mo)}{dm}=\int{\frac{1}{t}}{dt}[/tex] the first part which could be written as [tex]\int{\frac{e^zdz}{z}}[/tex] I don't suppose has a definite integral in closed form.
How do you get that? I'm pretty sure that the first integral is a fairly straightforward computation once you make a substitution.
Dec27-06, 01:55 AM   #7
Recognitions:
Let m=e^x then we get [tex]\int{\frac{dx}{x-log m(0)}[/tex]
Dec27-06, 02:03 AM   #8
You're missing a factor of e-x which then gives you something you can't integrate, but if you make the substitution u=log(m/m0) then you end up with the integral of 1/u with respect to u.
Dec27-06, 04:10 AM   #9
MWM
We may just notice that 1/m is the 1st derivative of (log(m/m0)) and that, then, the first integral contains an expression dividing its derivative: integrate[D(log(m/m0))]/log(m/m0)]dm. But this is just log|log(m/m0)|+c; isn't it?
Dec27-06, 04:14 AM   #10
Quote by MWM View Post
Yes that's it, and this is the same solution you arrive at using the substitution I mentioned, and is pretty much the sam process.
Dec27-06, 04:19 AM   #11
MWM
Ah, you're right. Ok... as if I hadn't said anything :-)
Dec27-06, 06:04 AM   #12
Ok thanks guys for your replies,
the thing is I don't get where the m has gone!!
surely the integral would be
[tex]\int{\frac{1}{m_{0}ue^{u}}}du[/tex]
Dec27-06, 04:02 PM   #13
How do you get to that? Try using the substitution u=log(m/m0) the integral will turn out very nicely.
Dec28-06, 06:40 AM   #14
Recognitions:
Homework Helper Homework Help
Let [itex]u=\log(m/mo)[/itex]
The integral:[tex]\int{\frac{1}{m\log(m/mo)}{dm}[/tex] becomes [tex]\int{\frac{1}{m\cdot u}{dm}[/tex]. Whats the derivative of log x? 1/x of course.
[tex]u=\log (m/mo)[/tex]
[tex]\frac {du}{dm} =\frac{1}{m}[/tex]
Substituting that in, our integral becomes [tex]\int \frac{1}{u} \frac {du}{dm} dm[/tex].
Dm's cancel out, thats why your m goes away!!
And obviously [tex]\int \frac{1}{u} du = \log u [/tex].
Now that looks the same form as the right hand side of your first post. Therefore [itex]t=\log (m/mo)[/itex]. Hopefully that was what you are looking for.
Dec29-06, 02:08 AM   #15
ssd
Quote by Gib Z View Post
You are right but I want to add,
ln(m/mo)=t+c, c is the constant of integration
Simplifying, ln(m)=t+k, k= c+ ln(mo).
Dec30-06, 12:16 AM   #16
Recognitions:
O yes sorry, forgot about the Constant, my bad. Ty for correcting me.
Dec30-06, 04:27 PM   #17
Recognitions:
What was wrong with substiting X=Log m?
Remember, if e^x=m then, e^xdx =dm; so ms in the top and bottem cancel out.
Thread Closed
Thread Tools
Similar Threads for: Integral of 1/ln(x)
Thread Forum Replies
integral more general then Lebesgue integral? Calculus 7
integral - Double integral Calculus & Beyond Homework 2
Need help w/ an integral Calculus 4
QM Integral and Online Integral Tables Calculus 5
Integral using integral tables Calculus 2
