Acceleration of Cart Rolling Down Incline
The problem involves a cart rolling down an incline, with specific parameters regarding its mass and moment of inertia. Participants are tasked with using conservation of energy to derive the acceleration of the cart along the incline.
  • Participants discuss the application of conservation of energy, questioning the derivation of terms related to the moment of inertia and rolling motion. There are attempts to clarify the relationship between translational and rotational kinetic energy.
The discussion is active, with participants exploring different interpretations of the equations involved. Some express uncertainty about the treatment of the moment of inertia and the factors contributing to the acceleration formula. There is no explicit consensus on the correctness of the book's solution.
Participants are working under the assumption of rolling without slipping and are trying to reconcile the given formula with their understanding of the physics involved. There is mention of potential discrepancies in the textbook's approach.
Dorothy Weglend
A cart is rolling down an incline (angle to horizontal is theta). It has two wheels, each wheel has mass m and moment of inertia mR^2/2. The total mass of the cart and the two wheels is M. Using conservation of energy (assuming no friction between cart and axles), show that the acceleration of the cart along the incline is a = [M/(M + 2m)] g sin theta.
K = Iw^2/2
K = mv^2/2
v = wR (w is angular velocity).
v^2 = 2as
E0 = E1
Ug = 2(K_rolling) + K_trans
Letting d be the distance traveled on the incline, this gives:
Mgd sin(theta) = (Iw^2/2)2 + Mv^2/2 = Iw^2 + Mv^2/2
Using the given moment of inertia I = mR^2/2:
Mgd sin(theta) = (mR^2/2)w^2 + Mv^2/2
Mgd sin(theta) = mv^2/2 + Mv^2/2
v^2 = 2Mgd sin(theta)/(M + m)
v^2 = 2ad:
a = Mg sin(theta)/(M + m)
I can't figure out where they got the 2m from.
I've tried adjusting the height by the radius of the wheels, but that gets complicated, because there are two of them, at two different heights, and I can't believe that would lead to the formula they give.
When you all recover from New Years, I'd appreciate any suggestions :wink:
Dorothy
(This is from Serway and Jewett, btw, 10.89)
Consider motion starting from rest over distance [tex]x[/tex] along the incline:
[tex]Mgx\sin\theta = \frac{1}{2}Mv^2 + 2(\frac{1}{2}mR^2)(\frac{v}{R})^2[/tex]
[tex]2Mgx\sin\theta = (M+2m)v^2[/tex]
On the other hand
[tex]v^2 = 2ax[/tex]
[tex]2Mgx\sin\theta = (M+2m)2ax[/tex]
[tex]a = \frac{Mg}{M+2m}\sin\theta[/tex]
Ok, but I don't understand how you got that rolling friction term.
Why isn't it
[tex]2(\frac{1}{2})(\frac{1}{2}mR^2)(\frac{v}{R})^2[/tex]
Isn't the KE of rolling friction
[tex](\frac{1}{2}){I\omega^2}[/tex]
Why would it be different in this case?
Thanks,
Dorothy
The condition states that the cart is rolling, which I suppose means that it's rolling without slipping. The condition for rolling without slipping is:
[tex]v=R\omega[/tex]
Dorothy, I agree with your solution. Is there a possibility that the book is wrong?
Hi Quirk... Yes, I understand that bit. What I don't understand is what happened to the 1/2 in Iw^2/2, or if you prefer, Iv^2/2R.
Hi Hawire,
That was my thought, yes, that the book was wrong. But I've thought that before (smile) and it wasn't. Just want to make sure I understand all of this.
  • · Replies 18 ·
  • · Replies 17 ·
