Isothermal Temperature: Real Life Examples of Constant Heat Flow
  • Thread starter Thread starter turdferguson
    Example Isothermal
The discussion focuses on real-life examples of isothermal processes, where temperature remains constant despite heat flow. Participants highlight melting and boiling as key examples, as they occur at constant temperature during phase transitions. Additionally, the process of pumping up a tire is discussed, where the air expands and cools, but heat from the surroundings maintains the ambient temperature. These examples illustrate the principles of thermodynamics in practical scenarios.
  • Understanding of thermodynamic concepts, specifically isothermal processes.
  • Familiarity with phase transitions, particularly melting and boiling.
  • Knowledge of gas laws, including the behavior of gases under pressure.
  • Basic principles of heat transfer and thermal equilibrium.
  • Research the principles of isothermal processes in thermodynamics.
  • Explore phase transitions in detail, focusing on melting and boiling points.
  • Study the ideal gas law and its applications in real-world scenarios.
  • Investigate heat transfer mechanisms, including conduction, convection, and radiation.
Students and professionals in thermodynamics, physics educators, and anyone interested in practical applications of heat transfer and phase changes.
turdferguson
I need to give examples of an instance in which temperature remains constant when heat flows in and out of a system, isothermal by definition. I know the textbook example (slowly heating an ideal gas in a cylinder with a piston on one end, volume increases as pressure decreases, etc.), but are there any real examples, analogous to the adiabatic example of streching a rubber band quickly?
I just realized that melting and boiling fit the criteria, but this is a thermo question, so any additional help would be appreciated
How about pumping up a tire? The air under pressure expands into the tire, which would tend to cool it. But because it is not insulated, heat from the surroundings flows into the air inside the tire and the temperature remains at the ambient temperature.
AM
  • · Replies 33 ·
9K
