Are gamma rays more dangerous than alpha or beta particles?
In summary: However, they are correct according to what I remember. Alpha radiation deposits 20 times more energy in body tissues than gamma or beta radiation, which is why alpha particles are more dangerous.
pivoxa15
2,255
Why are gamma rays potentially more dangerous than either alpha particles or beta particles?
none
Is it because gamma rays travel more distance before ionising matter so when a gamma ray is fired at you, it could get well inside your body and damage your internal cells. Whereas alpha and beta particles, even though carry more energy, ionises much more quickly, without traveling far so it may just damage the outer parts of your body which consists of dead cells anyway.
Gamma rays are more dangerous outside the body for precisely the reasons you state. Alpha particles are 'stopped' if you like by a few cm of air, so unless you are close to an alpha emitter, very few (if any particles are going to reach you). Once in the air, alpha particles can gain electrons and become helium atoms once more. Beta particles have a much higher energy than that of an alpha particle and thus are considered more penetrating. That said, they usually only penetrate a cm or so into tissue so damage is usually limited to skin and eyes; beta particles can be shielded by a thin sheet of metal. Gamma rays on the other hand are EM waves and cannot be 'stopped'; shielding can be used to reduce the intensity of the wave but can never completely negate the radiation. Therefore, gamma rays can pass through your body depositing energy in your tissues are it propagates.
However, inside body tissues, alpha radiation is by far the most dangerous since it is highly energetic and has a strong ability to ionise other atoms. If memory serves correctly (Medical Physicists chip in here) alpha radiation deposited 20 times more energy in body tissues that gamma or beta radiation. So if alpha particles actually reach you (or worse are inside your body close to your vital organs) they are going to deposit large amounts of energy in your tissues; thus causing damage.
What is 20? What units should be attached. What do you mean by deposit large amounts of energy? You mean they will convert their kinetic energy to kinetic energy in your cells via collision hence damaging your cells.
Sorry, typo, I should have said 20* times more, I've corrected this in my post. The unit of the measure of absorption in human tissue is the gray.
Yes, this can cause some cell damage. However, I should have mentioned in my previous post that it is the ionising ability of alpha radiation which causes the more serious effects such as mutations when it interacts with a cells DNA (I also seem to remember from somewhere that alpha radiation causes around 100* times more chromosome damage than gamma or beta). Mutations can cause cancer and/or sterilisation and other effects. Since, the alpha particle has a large charge (twice that of a better particle) and a large mass it interacts with electrons in atoms strong, thus ionising further atoms.
And I do apologise, I'm not making a very strong case for gamma rays to be the more dangerous form of radiation. However, your answer is essentially correct; the key point is that no matter how much shielding you put in place some gamma radiation will still penetrate it (although it will be significantly reduced), you can never completely 'stop' gamma rays since they are EM waves.
[tex]\hline[/tex]
*I'm recalling these figures from (a rather unused) memory, so I wouldn't quote these numbers in your answer without a reference.
What are gamma rays?
Gamma rays are a type of electromagnetic radiation with the shortest wavelength and highest energy on the electromagnetic spectrum. They are produced by the decay of atomic nuclei and can also be created in nuclear reactions.
Are gamma rays dangerous?
Yes, gamma rays can be dangerous to living organisms. They have high energy and can penetrate deeply into the body, causing damage to cells and DNA. Exposure to high levels of gamma rays can lead to radiation sickness and even death.
How do we protect ourselves from gamma rays?
There are several ways to protect ourselves from gamma rays. Shielding materials, such as lead or concrete, can be used to block gamma rays. Additionally, limiting exposure time and distance from a gamma ray source can also reduce the risk of harm.
What are the sources of gamma rays?
Gamma rays can be produced naturally from radioactive elements, such as uranium and radium, as well as from astronomical events, such as supernovas. They can also be created artificially through nuclear reactions in power plants and medical equipment.
Can we use gamma rays for anything beneficial?
Yes, gamma rays have many practical uses in various fields. They are used in medical imaging, cancer treatment, and sterilization processes. They are also used in industrial applications, such as detecting leaks and preserving food. However, proper safety measures must be taken when working with gamma rays.
  • Nuclear Engineering
