How Do You Calculate Forces and Friction in Everyday Motion Scenarios?
  • Thread starter Thread starter pharm89
    Motion Surface
The discussion revolves around calculating forces and friction in scenarios involving motion, specifically focusing on a situation where a person is carrying a cake box while riding a bus. The original poster presents multiple parts of the problem, including calculating the force exerted on a string, determining the coefficient of static friction, and assessing whether the box slides during sudden braking.
  • Mixed
  • Participants explore the application of Newton's second law, questioning the calculations of forces and friction. There are discussions on the importance of free body diagrams (FBD) to visualize forces acting on the box. Some participants express confusion regarding the units used in calculations and the role of gravity in determining net forces.
There is ongoing dialogue about the correct approach to solving the problems, with some participants offering guidance on drawing FBDs and checking calculations. Multiple interpretations of the problem are being explored, particularly regarding the effects of gravity and the proper use of formulas.
Participants note potential misunderstandings regarding the conversion of units and the relationship between acceleration and force. The discussion highlights the need for clarity on the definitions and roles of various forces in the context of the problem.
pharm89
Hi, I just want to know if I am on the right track with the answers I have came up. Thanks for everyone's help.
1. (a) Cathy takes the bus home form work. In her hand she holds a 2.0 kg cake box, tied together with a string. As she ascends the steps into the bus, the box accelerates upward at a rate of 2.5 m/s^2. What is the force exerted on the string?
(b) Cathy sets the box on the seat beside her. The bus accelerates form rest to 60.0 km/h in 4.0 s, and the box begins to slide. What is the coefficient of static friction between the box and the seat of the bus?
(c) A taxi suddenly cuts in front of the bus, causing the bus driver to slam on the brakes. The bus driver reduces speed from 60.0 km/h to 20.0 km/h in 1.5 s. Does Cathy's cake slide forward?
F=m(a)
formula for finding the coefficient of friction (I think...)
U = F(k) / F(n)
(a) F= m(a)
=(2.0 kg) (2.5 m/s)
=5 N
(b) U = F(k) /F(n)
=16.67 m/s /5 N
= 3.3
(c) My first inclination would be that Cathy's cake would slide. However, in tring to figure out how to prove this I wasn't quite sure except posssibly using the distance formula.
d=1/2 (v1 + v2) t
=1/2(60 m/s + 20 m/s) 1.5
=60 m
(this seems like an awful big number and doesn't make sense)
Am I missing a certain concept here?
Thanks for the help
Pharm89
pharm89 said:
(a) F= m(a)
=(2.0 kg) (2.5 m/s)
=5 N
You should draw a free body diagram (FBD) to understand this better. You have the force of the string, and the force of gravity, and some kind of motion. You need to write the equation for the net force and solve that.
(b) U = F(k) /F(n)
=16.67 m/s /5 N
= 3.3
I don't even have to check the math to know this is not right. Look at your units. Remember that Force has units of Newtons. You are dividing a velocity by a force.
I would suggest solving most of these problems symbolically, and only adding the numbers as the final step. It helps reduce errors, and it can provide a bit more insight.
d=1/2 (v1 + v2) t
=60 m
You should again draw a FBD to see the forces more clearly. Write the equation, and see what you get.
Dorothy
okay part A is good.
for part B, first you should know that it is wrong because your U should be between 0 and 1. Now I think you should make sure you are converting to m/s(sq) correctly. Make sure you first change to killometers per hour and then divide by 60 then by 60 again. Multiply your acceleration by the mass to find the frictional force. I think you are good from there.
For part C, first do the same thing as in part B but you can once you find the force on the block, you just need to see if it is more or less than the frictional force that you already calculated.
I don't agree. You are both neglecting the contribution of gravity.
I thought the equation for net force was F(net) =m(a)
I agree that you should take into account gravity (9.8 m/s^2) but how would you incorporate that into the above equation?
Thanks
:confused: Pharm 89
Thanks
:confused: Pharm 89
The forces on the box replace F_net.
I really would encourage you to draw FBD diagrams, even for these simple problems. It's a good habit to develop.
Dorothy
Dorothy
i substituted 9.8 m/s^2 for F_net, still using the same varibles for mass and acceleration and solved for X. and Icame up with 0.51 N?
Or is my method simply wrong.
Thanks
Pharm89
Thanks
Pharm89
9.8 m/s^2 is an acceleration. F=ma, so you have to multiply it by m to get a force. I hope you don't mind me mentioning that you make this mistake a lot, maybe just something to remember to check.
On your FBD diagram, you'll have two arrows. One pointing up, that represents the force of the string. One pointing down, that represents the force of gravity (these are vector forces). You can put a third arrow off to the side, pointing up, to indicate the direction of acceleration, that's helpful too.
Then select a direction to consider positive, let's say up is positive. The vector sum of these two forces is the net force, and equals ma. That's the meaning of the second law.
Dorothy
Dorothy
Thanks for your help with this problem. It makes more sense to me know.
Pharm89
You're welcome, it's my pleasure.
Dorothy
  • · Replies 23 ·
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 19 ·
