Calculate Center of Mass for 1.05cm Baseball Bat with Linear Density Formula
  • Thread starter Thread starter HandcuffedKitty
    Coordinate
The center of mass for a 1.05 cm baseball bat with a linear density function defined as λ(x) = 0.950 + 1.050x²/l² can be calculated using integral calculus. The total mass of the bat is derived from the integral of the linear density function over its length, resulting in m = 0.9975 + 0.3864/l². The x-coordinate of the center of mass is computed using the formula xcm = ∫x*(λ(x)) dx / m, yielding xcm = (1.100625 + 1.264625/l²) / (0.9975 + 0.3864/l²).
  • Understanding of integral calculus
  • Familiarity with linear density functions
  • Knowledge of center of mass calculations
  • Basic proficiency in mathematical notation and manipulation
  • Study the application of integral calculus in physics problems
  • Learn about linear density and its implications in mass distribution
  • Explore advanced center of mass calculations for irregular shapes
  • Investigate the effects of varying linear density on the center of mass
Students in physics or engineering, educators teaching mechanics, and anyone interested in applying calculus to real-world physical problems.
HandcuffedKitty
A baseball bat of length 1.05 cetimeters has a lenear density given by l=.950 + 1.050x^2/l^2 find the x cooridinate of the center of mass in centimeters.
How am I supposed to work this problem?
Center of mass is a weighted average. Each part's contribution, all other things being equal, increases proportional to distance from the origin as one moves away from the origin. Just combine "average" and "weighted" to get:
[tex]\overline{x} = \frac{\int^a_bx\lambda(x)dx}{\int^a_b\lambda(x)dx}[/tex]
where [a,b] is the region describing the bat (0 to 1.05 in your case) and [itex]\lambda(x)[/itex] is the linear density function in terms of x. You'll notice that the top half of the fraction is the "weighted" part, which you're dividing by the total mass to get the "average" part.
cookiemonster
To calculate the center of mass for a 1.05cm baseball bat with a linear density formula, we can use the following steps:
Step 1: Determine the total mass of the baseball bat. We can do this by integrating the linear density function over the length of the bat. In this case, the length of the bat is 1.05cm, so the total mass would be:
m = ∫(0.950 + 1.050x^2/l^2) dx from x = 0 to x = 1.05
m = (0.950x + 0.350x^3/l^2) from x = 0 to x = 1.05
m = (0.950*1.05 + 0.350*1.05^3/l^2) - (0.950*0 + 0.350*0^3/l^2)
m = 0.9975 + 0.3864/l^2
Step 2: Determine the x coordinate of the center of mass. This can be done using the formula:
xcm = ∫x*(linear density function) dx / m from x = 0 to x = 1.05
xcm = (x*(0.950 + 1.050x^2/l^2) dx) / (0.9975 + 0.3864/l^2) from x = 0 to x = 1.05
xcm = (0.950x^2/2 + 1.050x^4/4l^2) / (0.9975 + 0.3864/l^2) from x = 0 to x = 1.05
xcm = (0.950*1.05^2/2 + 1.050*1.05^4/4l^2) / (0.9975 + 0.3864/l^2) - (0.950*0^2/2 + 1.050*0^4/4l^2) / (0.9975 + 0.3864/l^2)
xcm = (1.100625 + 1.264625/l^2) / (0.9975 + 0.3864/l^2)
xcm = (1.100625 +
