How is this related to entropy?
  • Thread starter Thread starter jlmac2001
    Entropy
The discussion revolves around the relationship between computer memory operations and entropy, specifically in the context of erasing or overwriting data. The original poster presents a problem involving the creation of entropy when a gigabyte of memory is erased, along with questions about the heat associated with this entropy when released into the environment.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the definition of entropy in both thermodynamic and information contexts, questioning how these concepts relate to computer memory and data processing. Some express uncertainty about how to quantify entropy in this scenario, while others discuss the implications of energy conversion and heat generation in computing.
The discussion is ongoing, with participants providing various perspectives on the nature of entropy and its relevance to information theory. Some guidance has been offered regarding the connection between thermodynamics and information, but there is no clear consensus on how to approach the calculations or the implications of the problem.
Participants note a potential gap in understanding due to differing backgrounds in thermodynamics and information theory. There is also mention of external resources that may aid in clarifying these concepts, but no specific solutions have been proposed yet.
jlmac2001
I don't get want a computer has to do with entropy. Can someone explain this question?
A bit of computer memory is some physical object that can be in two different states, often interpreted as 0 to 1. A byte is eight bits, a kilobyte is 1024 (=2^10) bytes, a megabyte is 1024 kilobyes and a gigabyte is 1024 megabytes.
A) Suppose that your computer erases or overwrites one gigabyte of memory, keeping no record of the information that was stored. Explain why this process must create a certain minimum amount of entropy and calculate how much.
B) If this entropy is dumped into an environment at room temperature, how much heat must come along with it? Is this amount of heat significant?
The following page might help you along:
http://www.kevinboone.com/compdict/information_theory.html
Entropy is a measure of the 'randomness' of data, which can be made mathematically precise. A string of random numbers has a high entropy, while a string of the identical numbers has a low entropy. At this point I am not sure how to put a number to it though :S
Perhaps I don't understand the question.
You can't "dump entropy". Entropy is a thermodynamic property...a quantification of the microscopic disorder of a system.
Entropy does not pertain to information and it's not something to build up, store, & shift around.
However, it takes energy to operate a computer, and in the process that energy is converted from a useful form (3-phase 120 V etc.) into a less useful form. Heat is typically the end of the line for "usefulness" of energy (like heat radiating off the processor or drives).
You dump heat to the room...and the entropy of the system is adjusted accordingly.
Significant compared to what?
Does Information Theory use the term entropy too? Because, IIRC, thermodynamics does not apply entropy to information.
Perhaps that's where I'm missing things. I'm trained in thermodynamics, not info theory.
With all due respect, this is wrong on both counts.
1. Entropy can be transferred from one thermodynamic system to another.
2. Entropy has everything in the world to do with information.
But like Monique, I don't know exactly how to calculate the answer. Ah, if only David were still with us. This was exactly his area of reasearch.
Anyone?
Yes, it does. You have to remember where classical thermodynamics comes from: Quantum Statistical Mechanics. Entropy, as all thermodynamic quantities, is derived from the partition function of a system. As a result, it inherits this link to information that is encoded discretely, as in the case of binary data. An increase in entropy corresponds to a degradation of information.
See this paper:
http://xxx.lanl.gov/PS_cache/quant-ph/pdf/0307/0307026.pdf
Unfortunately, this paper is far above the level of the question posed in this thread. Maybe if I figure out how to extrapolate down to erasing 1 GB on a computer, I will post the solution (but don't hold your breath).
Shannon entropy, or information entropy, has been related to t-dynamic entropy by the black hole crowd; the result is NOT universally accepted, and it's not something I've bothered to track down in detail --- Kip Thorne has tried writing it up for "the masses," but in doing so, skipped all the gory details --- someone wants to search "Shannon," or "information theory," lota of luck.
how can you dump entropy? could you be more specific?
Hmm. Guess my misunderstanding stems from the application of the law (I studied it back in college as it applied to mechanical engineering). Or maybe that info has atrophied/entropied in my brain from lack of use since college many years ago.
Here is a cool example of entropy in information technology:
The information density of the contents of the file, expressed as a number of bits per character. The results above, which resulted from processing an image file compressed with JPEG, indicate that the file is extremely dense in information--essentially random. Hence, compression of the file is unlikely to reduce its size. By contrast, the C source code of the program has entropy of about 4.9 bits per character, indicating that optimal compression of the file would reduce its size by 38%. [Hamming, pp. 104-108]
