How do I find the man's speed when depressing the platform 0.120 m?
  • Context: Undergrad
  • Thread starter Thread starter lollypop
    Spring
The discussion revolves around a physics problem involving an 80.0-kg man jumping onto a spring-mounted platform. Participants are trying to determine the man's speed when the platform is depressed by 0.120 m and the maximum distance the platform would compress if the man steps gently onto it. The conversation includes aspects of potential energy, spring constants, and the application of energy conservation principles.
  • Homework-related
  • One participant suggests using the potential energy formula U=mgh to find the man's speed and expresses confusion about how to derive the spring constant k.
  • Another participant proposes that at maximum compression, the potential energy in the spring equals the gravitational potential energy, leading to the equation PE_{spring}=mgh.
  • There is a discussion about the correct distance to use in the equations, with one participant asking for clarification on which displacement x to apply.
  • One participant derives the spring constant k using the relationship k=2mgh/x^2, indicating that h is the height from which the man drops and x is the spring displacement.
  • Another participant reports calculating k as 373332 N/m and a displacement of 2 cm, while another participant calculates k as 68055 N/m, yielding a velocity of 6.06 m/s.
  • There is uncertainty regarding the correct method to find the maximum compression distance when the man steps gently onto the platform, with one participant suggesting that energy considerations might yield a different equation.
  • Participants express frustration over discrepancies in their results and discuss the possibility of needing more significant figures in their answers.
  • One participant shares their calculations for gravitational potential energy and the spring constant, suggesting that they should be able to solve the problem easily if their calculations are correct.
Participants do not reach a consensus on the correct value of the spring constant or the maximum compression distance. Multiple competing views and calculations are presented, and the discussion remains unresolved.
There are limitations regarding the assumptions made about friction and the exact distances used in calculations, which remain unresolved throughout the discussion.
lollypop
hello, if anyone can help me figure this out, it will be appreciated.
the problem is the following:
An 80.0-kg man jumps from a height of 2.50 m onto a platform mounted on springs. As the springs compress, he pushes the platform down a maximum distance of 0.240 m below its initial position, and then it rebounds. The platform and springs have negligible mass.
a)What is the man's speed at the instant he depresses the platform 0.120 m?
b)If the man just steps gently onto the platform, what maximum distance would he push it down?
I found the potential energy when the man hits the spring by U=mgh,
i also need the spring constant and this is where i get confused on how to get it.
Do i use F=kx, the F being the weight?and then plug into find w=0.5kx^2, and then finally find v??
I also get confused as to which distances to use on the equations
Any help would be great!
thanks.
At the point where the spring is fully compressed you've got:
[tex]PE_{spring}=mgh[/tex]
for the second part you've got:
[tex]kx=mg[/tex]
which is also relatively easy to solve.
thanks for ur reply NateTG, but still I get confused on how to get the constant k, on the equations u sent, they use x as distance, which distance should i use??
Let's find [tex]k[/tex]
[tex]mgh=\frac{1}{2}kx^2[/tex]
so
[tex]k=\frac{2mgh}{x^2}[/tex]
where h is the height the man dropped, and x is the spring displacement.
hey thanks!, i got the first part for the velocity ,but the equation that you gave me for the second part, to find the distance as the man steps on the spring kx=mg is not giving me the right answer, is there another way of finding that distance?
I get
[tex]k=373332 N/m[/tex]
so I get a displacement of [tex]2cm[/tex] what do you get?
i get for the first part k=68055 N/m, which gave me a velocity
of 6.06 m/s, which is right.
But when i use that same k for the second part, i get 0.0115 m
for the displacement, and it says its wrong.
Hmm, do you know what the correct answer is supposed to be? You would get a different equation if you try disregard friction, and solve part 2 with energy.
no, i don't know the answer,i put the answer on a website and it tells me wheter I'm right or not. I still have 6 tries left :wink:
I supposed the answer would be smaller than 0.240 m which was the compression when the man jumped, I plugged in yours, 2 cm , 0.02 m , and is also wrong.i'll keep trying with what u said about not using friction and doing it with kinetic, thanks.
hey, i think they wanted more sig figs, the anwer was 0.0210 m,
i just requested it, because i got the same as you did when i worked it out.
mgy=1/2kx^2
mgy=1/2kx^2
is all you need for these problems
hold on While I do the calculations
Worked out
MGY
80*2.5*9.8=1960
1960=1/2K*.254^2
K=68055.55556
Then you can F=-kx
F=-16333.3333
you shoudl be able to solve the rest fairly easily... if i did it right hope i helped in some way
