Where is the center of gravity of this person
The center of gravity of a 160 cm tall person lying on a massless board is calculated using the readings from two scales: 29.4 kg under the feet and 32.8 kg under the head. The center of gravity is located 84.4 cm from the bottom of the feet, determined by balancing the forces and calculating torque. Additionally, for a traffic light scenario involving a 4.5 m aluminum pole weighing 5.0 kg and a 10.0 kg light, the tension in the horizontal cable and the forces at the pivot can be analyzed using equilibrium conditions and free body diagrams.
  • Understanding of equilibrium conditions in physics
  • Knowledge of torque and its calculation
  • Familiarity with free body diagrams
  • Basic concepts of weight and force (e.g., Newton's second law)
  • Learn about calculating torque in various systems
  • Study equilibrium conditions for static structures
  • Explore free body diagram techniques for complex systems
  • Investigate the principles of center of mass in different configurations
Students in physics, engineers working with static structures, and anyone interested in understanding the mechanics of forces and torques in real-world applications.
Gauss177
1. A 160 cm tall person lies on a light (massless) board which is supported by two scales, one under the feet and one beneath the top of the head. The scale under the feet reads 29.4 kg and the one under the head reads 32.8 kg. Where is the center of gravity of this person measured from the bottom of the feet?
My thoughts:
The person would feel 321.4 N (32.8 kg * 9.8) pushing up at the head, and 288.1 N (29.4 kg * 9.8) pushing up at the feet. The force of mg would be an arrow pointing down under the center of gravity, located x meters from the bottom of the feet. For person to be in equilibrium, Fnet must equal 0, so:
321.4 N + 288.1 N = F
F = 609.6 N
Also, torque must also equal 0, so:
321.44(1.6) = 609.56(x)
x = .844 m, or 84.4 cm from the bottom of the feet.
Is this correct?
2. A traffic light hangs from a structure as shown in the attached picture. The uniform aluminum pole AB is 4.5 m long and weighs 5.0 kg. The weight of the traffic light is 10.0 kg. Determine the tension in the horizontal massless cable CD, and the vertical and horizontal components of the force exerted by the pivot A on the aluminum pole.
My thoughts:
I drew a free body diagram of the aluminum pole AB, and made the point A as my "fulcrum." Then, I would only have to worry about mg of the pole (5*9.8=49 N), Mg of the light (10*9.8=98 N), and tension T exerted by the cable CD. I split T into its components, Tx and Ty, and since Fnet must equal 0 for it to be at equilibrium:
Ty = 49 + 98 = 147 N
Therefore, Tx = 147 tan 37 = 110.72 N
I'm really not sure how to do the second part: finding the vertical and horizontal components of the force exerted by the pivot on the pole. I'm probably not visualizing it correctly, so please help.
Is this correct?
The torque about any point must be 0. Let's pick the centre of mass (you can pick either fulcrum and work out the expression for the torque of the centre of mass about that point).
The torque about the centre of mass must be 0. Let's say the centre of mass is a distance x from the feet. The torque is:
[tex]\tau = F_{head}\times (L-x) + F_{feet}\times x = 0[/tex]
Work that out.
AM
9K
12K
