Is Pressure on an Item Underwater Equal in All Directions?
The discussion revolves around the concept of pressure exerted on an object submerged underwater, particularly focusing on whether this pressure is equal in all directions and how it relates to buoyancy. Participants explore the implications of pressure changes with depth and the behavior of air in a submerged context.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants discuss the uniformity of pressure at a certain depth and its implications for buoyancy. Questions arise regarding the behavior of air under pressure and the mechanics of releasing air from a submerged chamber.
The conversation is ongoing, with participants providing insights into the nature of pressure and buoyancy. Some guidance has been offered regarding the behavior of air at depth, but clarity on specific scenarios is still being sought.
There is a mention of constraints related to the equipment used for pumping air and the conditions at a depth of eight feet, including the presence of a check valve that allows air to move but prevents water from entering.
2112
When an item is submerged underwater, I believe that pressure from the surrounding water is equal in pressure around the item except from beneath, is this correct?
The pressure exerted by a liquid increases linearly with depth, i.e. the deeper you go the more pressure is exerted. However, this pressure is exerted uniformly at a certain 'level' in all directions. Therefore, there is a greater force (note force not pressure) pushing a submerged object upwards than downwards; i.e. there is a net force upwards. This is buoyancy.
If you might indulge me,? , if I wanted to pump air too, say a depth of eight feet, and I only was equipped with something with a low psi, (very minimal psi), how would it be easier to have the air break the barrier of pressure/force to escape its chamber?
Would I have a better chance at trying to get the low pressure air out by pointing it upwards or down, (at that eight foot level).
Before I forget there is a sort of check valve on it that won't let water through its outlet, but air can move freely through it.
With a little thought and be reading what I have posted above, you should be able to answer this question yourself.
I'm confused. Are you pumping air down? "pump air too, say a depth of eight feet"
Or are you pumping the air up? "escape its chamber?", "get the low pressure air out by pointing it upwards or down, (at that eight foot level)."
The air goes down through a hose to a depth of 8 foot, I just wondered how best under the circumstances could I get an air bubble come up from that depth.
Well, unless your container at the 8 foot level is both rigid in structure and held securely in place, the air down there will happily come up from that depth without any help from you... Your container will implode, or it will rocket to the surface.
OTOH, if it is both those things, then you move air to and fro with free abandon. You could blow in it if you chose.
Look, it seems tome you're beating around the bush. I think you're going to need to illustrate what you are talking about if you want meaningful answers.
Thanks for the answers, you gave me a better understanding of force and pressure and I appreciate the help!
